Products
Products
    Ethernet routers
    hEX lite
    hEX lite
    5x Ethernet, Small plastic case, 850MHz CPU, 64MB RAM, Most affordable MPLS router, RouterOS L4
    Compare
    $39.95
    hEX
    hEX
    5x Gigabit Ethernet, Dual Core 880MHz CPU, 256MB RAM, USB, microSD, RouterOS L4
    Compare
    $59.95
    hEX PoE lite
    hEX PoE lite
    5xEthernet with PoE output for four ports, USB, 650MHz CPU, 64MB RAM, RouterOS L4
    Compare
    $59.95
    PowerBox
    PowerBox
    650MHz CPU, 64MB RAM, 5xEthernet with PoE output for four ports, RouterOS L4, outdoor case, PSU
    Compare
    $69.00
    hEX S
    hEX S
    5x Gigabit Ethernet, SFP, Dual Core 880MHz CPU, 256MB RAM, USB, microSD, RouterOS L4, IPsec hardware encryption support and The Dude server package
    Compare
    $69.00
    hEX PoE
    hEX PoE
    5x Gigabit Ethernet with PoE output for four ports, SFP, USB, 800MHz CPU, 128MB RAM, RouterOS L4
    Compare
    $79.00
    RB2011iL-IN
    RB2011iL-IN
    Desktop metal case, 5xEthernet, 5xGigabit Ethernet, PoE out on port 10, 600MHz CPU, 64MB RAM, RouterOS L4
    Compare
    $99.00
    RB2011iL-RM
    RB2011iL-RM
    1U rackmount, 5xEthernet, 5xGigabit Ethernet, PoE out on port 10, 600MHz CPU, 64MB RAM, RouterOS L4
    Compare
    $99.00
    PowerBox Pro
    PowerBox Pro
    Five Gigabit Ethernet Router with 4xPoE-out ports, SFP cage and outdoor enclosure
    Compare
    $99.00
    RB2011iLS-IN
    RB2011iLS-IN
    Desktop metal case, 5xEthernet, 5xGigabit Ethernet, SFP cage, PoE out on port 10, 600MHz CPU, 64MB RAM, RouterOS L4
    Compare
    $109.00
    RB2011UiAS-IN
    RB2011UiAS-IN
    Desktop metal case, 5xEthernet, 5xGigabit Ethernet, USB, LCD, PoE out on port 10, 600MHz CPU, 128MB RAM, RouterOS L5
    Compare
    $119.00
    RB2011UiAS-RM
    RB2011UiAS-RM
    1U rackmount, 5xEthernet, 5xGigabit Ethernet, USB, LCD, PoE out on port 10, 600MHz CPU, 128MB RAM, RouterOS L5
    Compare
    $119.00
    RB3011UiAS-RM
    RB3011UiAS-RM
    1U rackmount, 10xGigabit Ethernet, SFP, USB 3.0, LCD, PoE out on port 10, 2x1.4GHz CPU, 1GB RAM, RouterOS L5
    Compare
    $179.00
    RB4011iGS+RM
    RB4011iGS+RM NEW
    Powerful 10xGigabit port router with a Quad-core 1.4Ghz CPU, 1GB RAM, SFP+ 10Gbps cage and desktop case with rack ears
    Compare
    $199.00
    RB1100AHx4
    RB1100AHx4
    Powerful 1U rackmount router with 13x Gigabit Ethernet ports
    Compare
    $299.00
    RB1100AHx4 Dude Edition
    Powerful 1U rackmount router with 13x Gigabit Ethernet ports, 60GB M.2 drive for Dude database
    Compare
    $349.00
    CCR1009-7G-1C-PC
    CCR1009-7G-1C-PC
    7x Gigabit Ethernet, 1x Combo port (SFP or Gigabit Ethernet), 9 cores x 1GHz CPU, 1GB RAM, passive cooling case, RouterOS L6
    Compare
    $425.00
    CCR1009-7G-1C-1S+PC
    CCR1009-7G-1C-1S+PC
    7x Gigabit Ethernet, 1x Combo port (SFP or Gigabit Ethernet), 1xSFP+ cage, 9 cores x 1GHz CPU, 2GB RAM, LCD panel, passive cooling desktop enclosure, SmartCard slot, RouterOS L6, PSU
    Compare
    $495.00
    CCR1009-7G-1C-1S+
    CCR1009-7G-1C-1S+
    1U rackmount, 7x Gigabit Ethernet, 1x Combo port (SFP or Gigabit Ethernet), 1xSFP+ cage, 9 cores x 1.2GHz CPU, 2GB RAM, LCD panel, Dual Power supplies, SmartCard slot, RouterOS L6
    Compare
    $495.00
    CCR1016-12G
    CCR1016-12G
    1U rackmount, 12x Gigabit Ethernet, LCD, 16 cores x 1.2GHz CPU, 2GB RAM, 17.8mpps fastpath, Up to 12Gbit/s throughput, RouterOS L6
    Compare
    $645.00
    CCR1016-12S-1S+
    CCR1016-12S-1S+
    1U rackmount, 12xSFP cage, 1xSFP+ cage, 16 cores x 1.2GHz CPU, 2GB RAM, LCD panel, Dual Power supplies, RouterOS L6
    Compare
    $745.00
    CCR1036-12G-4S
    CCR1036-12G-4S
    1U rackmount, 12x Gigabit Ethernet, 4xSFP cages, LCD, 36 cores x 1.2GHz CPU, 4GB RAM, 24 mpps fastpath, Up to 16Gbit/s throughput, RouterOS L6
    Compare
    $995.00
    CCR1036-8G-2S+
    CCR1036-8G-2S+ NEW
    1U rackmount, 8x Gigabit Ethernet, 2xSFP+ cages, LCD, 36 cores x 1.2GHz CPU, 4GB RAM, 41.5mpps fastpath, Up to 28Gbit/s throughput, RouterOS L6, Dual PSU
    Compare
    $1095.00
    CCR1036-12G-4S-EM
    CCR1036-12G-4S-EM
    1U rackmount, 12x Gigabit Ethernet, 4xSFP cages, LCD, 36 cores x 1.2GHz CPU, 16GB RAM, 24 mpps fastpath, Up to 16Gbit/s throughput, RouterOS L6
    Compare
    $1195.00
    CCR1036-8G-2S+EM
    CCR1036-8G-2S+EM NEW
    1U rackmount, 8x Gigabit Ethernet, 2xSFP+ cages, LCD, 36 cores x 1.2GHz CPU, 8GB RAM, 41.5mpps fastpath, Up to 28Gbit/s throughput, RouterOS L6, Dual PSU
    Compare
    $1295.00
    CCR1072-1G-8S+
    CCR1072-1G-8S+
    1U rackmount, 1x Gigabit Ethernet, 8xSFP+ cages, LCD, 72 cores x 1GHz CPU, 16GB RAM, up to 120 million packets per second, 80Gbps throughput, RouterOS L6
    Compare
    $3050.00
    Switches
    RB260GS
    RB260GS
    5x Gigabit Ethernet Smart Switch, SFP cage, plastic case, SwOS
    Compare
    $39.95
    RB260GSP
    RB260GSP
    5x Gigabit PoE out Ethernet Smart Switch, SFP cage, plastic case, SwOS
    Compare
    $55.95
    CRS106-1C-5S
    CRS106-1C-5S
    Smart Switch, 5x SFP cages, 1x Combo port (SFP or Gigabit Ethernet), 400MHz CPU, 128MB RAM, desktop case, RouterOS L5
    Compare
    $59.00
    FiberBox
    FiberBox
    An outdoor switch with five SFP ports
    Compare
    $79.00
    CRS112-8G-4S-IN
    CRS112-8G-4S-IN
    8x Gigabit Ethernet Smart Switch, 4x SFP cages, 400MHz CPU, 128MB RAM, desktop case, RouterOS L5
    Compare
    $139.00
    CSS326-24G-2S+RM
    CSS326-24G-2S+RM
    SwOS powered 24 port Gigabit Ethernet switch with two SFP+ ports in 1U rackmount case
    Compare
    $139.00
    CRS109-8G-1S-2HnD-IN
    8x Gigabit Smart Switch, 1x SFP cage, LCD, 802.11b/g/n Dual Chain wireless, 600MHz CPU, 128MB RAM, Metal desktop case, RouterOS L5, supports 10-57V, 802.3af/at compliant
    Compare
    $149.00
    CRS305-1G-4S+IN
    CRS305-1G-4S+IN NEW
    Five-port desktop switch with one Gigabit Ethernet port and four SFP+ 10Gbps ports
    Compare
    $149.00
    CRS112-8P-4S-IN
    CRS112-8P-4S-IN
    8x Gigabit Ethernet Smart Switch with PoE-out, 4x SFP cages, 400MHz CPU, 128MB RAM, desktop case, RouterOS L5
    Compare
    $179.00
    CRS125-24G-1S-IN
    CRS125-24G-1S-IN
    24x Gigabit Ethernet layer 3 Smart Switch, 1x SFP cage, LCD, 600MHz CPU, 128MB RAM, Metal desktop case, RouterOS L5
    Compare
    $189.00
    CRS326-24G-2S+RM
    CRS326-24G-2S+RM
    24 Gigabit port switch with 2 x SFP+ cages in 1U rackmount case, Dual boot (RouterOS or SwitchOS)
    Compare
    $199.00
    CRS125-24G-1S-2HnD-IN
    24x Gigabit Ethernet layer 3 Smart Switch, 1x SFP cage, LCD, 802.11b/g/n Dual Chain wireless, 600MHz CPU, 128MB RAM, Metal desktop case, RouterOS L5
    Compare
    $209.00
    CRS212-1G-10S-1S+IN
    CRS212-1G-10S-1S+IN
    Smart Switch, 1x Gigabit LAN, 10x SFP cages, 1x SFP+ cage, LCD, 400MHz CPU, 64MB RAM, Metal desktop case, RouterOS L5
    Compare
    $219.00
    CRS309-1G-8S+IN
    CRS309-1G-8S+IN NEW
    Desktop switch with one Gigabit Ethernet port and eight SFP+ 10Gbps ports
    Compare
    $269.00
    CRS328-4C-20S-4S+RM
    CRS328-4C-20S-4S+RM
    Smart Switch, 20 x SFP cages, 4 x SFP+ cages, 4 x Combo ports (Gigabit Ethernet or SFP), 800MHz CPU, 512MB RAM, 1U rackmount case, Dual Power Supplies, RouterOS L5 or SwitchOS (Dual Boot)
    Compare
    $369.00
    CRS328-24P-4S+RM
    CRS328-24P-4S+RM
    24 port Gigabit Ethernet router/switch with four 10Gbps SFP+ ports in 1U rackmount case, Dual Boot and PoE output, 500W
    Compare
    $379.00
    CRS317-1G-16S+RM
    CRS317-1G-16S+RM
    Smart Switch, 1 x Gigabit LAN, 16 x SFP+ cages, Dual Core 800MHz CPU, 1GB RAM, 1U rackmount passive cooling case, Dual Power Supplies
    Compare
    $399.00
    Wireless systems
    LDF 5
    LDF 5
    Dual chain 5GHz system for long distance links with satellite offset dish antennas
    Compare
    $39.00
    SXTsq Lite2
    SXTsq Lite2
    Low-cost small-size 10dBi 2.4GHz dual chain integrated CPE/Backbone
    Compare
    $39.00
    LDF 2
    LDF 2
    Dual chain 2.4GHz system for long distance links with satellite offset dish antennas
    Compare
    $39.00
    SXTsq Lite5
    SXTsq Lite5
    Low-cost small-size 16dBi 5GHz dual chain integrated CPE/Backbone
    Compare
    $46.00
    DISC Lite5
    DISC Lite5
    Dual chain 21dBi 5GHz CPE/Point-to-Point Integrated Antenna, 600Mhz CPU, 64MB RAM
    Compare
    $48.00
    SXTsq 5 High Power
    SXTsq 5 High Power
    Low-cost High Power small-size 16dBi 5GHz dual chain integrated CPE/Backbone
    Compare
    $49.00
    SXTsq 5 ac
    SXTsq 5 ac
    Low-cost small-size 16dBi 5GHz dual chain integrated CPE/Backbone with AC support and Gigabit Ethernet
    Compare
    $55.00
    LHG 2
    LHG 2
    Dual chain 18dBi 2.4GHz CPE/Point-to-Point Integrated Antenna, 600Mhz CPU, 64MB RAM
    Compare
    $58.00
    DISC Lite5 ac
    DISC Lite5 ac
    Outdoor 5GHz 802.11a/n/ac wireless device with a backfire type 21dBi integrated antenna and Gigabit Ethernet for longer distances
    Compare
    $58.00
    SXT Lite5
    SXT Lite5
    16dBi integrated CPE/Backbone, 5GHz dual chain, 600MHz CPU
    Compare
    $59.00
    Groove 52
    Groove 52
    2.4GHz/5GHz Backbone/CPE, N-male connector
    Compare
    $59.00
    LHG 5
    LHG 5
    Dual chain 24.5dBi 5GHz CPE/Point-to-Point Integrated Antenna, 600Mhz CPU, 64MB RAM
    Compare
    $59.00
    LDF 5 ac
    LDF 5 ac
    Dual chain 5GHz system with Gigabit Ethernet and 802.11ac support for long distance links with satellite offset dish antennas
    Compare
    $59.00
    LHG XL 2
    LHG XL 2
    Dual chain 21dBi 2.4GHz CPE/Point-to-Point Integrated Antenna for longer distances
    Compare
    $68.00
    LHG HP5
    LHG HP5
    Dual chain High Power 24.5dBi 5GHz CPE/Point-to-Point Integrated Antenna
    Compare
    $69.00
    SXTsq Lite60
    SXTsq Lite60 NEW
    For use as 60GHz CPE in Point -to-Multipoint setups for connections up to 200m with wAP 60G AP, low cost version
    Compare
    $69.00
    SXT 2
    SXT 2
    10dbi 60 degree integrated AP/Backbone/CPE, dual chain, Gigabit Ethernet
    Compare
    $79.00
    GrooveA 52
    GrooveA 52
    2.4GHz/5GHz AP/Backbone/CPE, N-male connector, includes 2.4GHz/5GHz 6dBi Omni Antenna
    Compare
    $79.00
    Groove 52 ac
    Groove 52 ac
    2.4GHz/5GHz Backbone/CPE with 802.11ac and Gigabit Ethernet, N-male connector
    Compare
    $79.00
    LHG XL HP5
    LHG XL HP5
    Dual chain eXtra Large High Power 27dBi 5GHz CPE/Point-to-Point Integrated Antenna
    Compare
    $79.00
    OmniTIK 5
    OmniTIK 5
    7.5dBi Integrated AP, 5GHz Dual chain, 5xEthernet ports
    Compare
    $89.00
    BaseBox 5
    BaseBox 5
    5Ghz integrated AP/Backbone/CPE, 2xRPSMA connectors, miniPCI-e slot, Gigabit Ethernet
    Compare
    $89.00
    BaseBox 2
    BaseBox 2
    2.4Ghz integrated AP/Backbone/CPE, 2xRPSMA connectors, miniPCI-e slot, Gigabit Ethernet
    Compare
    $89.00
    LHG 5 ac
    LHG 5 ac
    Dual chain 24.5dBi 5GHz CPE/Point-to-Point Integrated Antenna with AC support and Gigabit Ethernet
    Compare
    $89.00
    BaseBox 6
    BaseBox 6 NEW
    6GHz integrated AP/Backbone/CPE, 2xRPSMA connectors, miniPCI-e slot, Gigabit Ethernet
    Compare
    $89.00
    OmniTIK 5 PoE
    OmniTIK 5 PoE
    7.5dBi Integrated AP, 5GHz Dual chain, 5xEthernet ports with PoE output
    Compare
    $99.00
    SXT SA5
    SXT SA5
    14dBi integrated Sector AP, 90 degrees beamwidth, Gigabit Ethernet
    Compare
    $99.00
    GrooveA 52 ac
    GrooveA 52 ac
    2.4GHz/5GHz AP/Backbone/CPE with 802.11ac and Gigabit Ethernet, N-male connector + Omni antenna
    Compare
    $99.00
    SXT 6
    SXT 6
    Dual chain 16dBi 28 degree 5.9-6.4GHz Integrated antenna for licensed band
    Compare
    $99.00
    LHG XL 5 ac
    LHG XL 5 ac
    Dual chain Long Range 27dBi 5GHz CPE/Point-to-Point Integrated Antenna with AC support and Gigabit Ethernet
    Compare
    $99.00
    wAP 60G
    wAP 60G
    60 GHz CPE with Phase array 60° beamforming Integrated antenna, 716 Mhz CPU, 256 MB RAM, PSU and PoE, RouterOS L3
    Compare
    $99.00
    mANTBox 2 12s
    mANTBox 2 12s
    2.4GHz 120 degree 12dBi dual polarization sector Integrated antenna with 600Mhz CPU, 64MB RAM, Gigabit Ethernet, PSU and PoE
    Compare
    $99.00
    LHG Lite60
    LHG Lite60 NEW
    For use as 60GHz CPE in Point -to-Multipoint setups for connections up to 800m with wAP 60G AP, low cost version with 10/100Mbps Ethernet port
    Compare
    $99.00
    NetBox 5
    NetBox 5
    802.11ac support for up to 540Mbits, waterproof enclosure, high output
    Compare
    $109.00
    OmniTIK 5 ac
    OmniTIK 5 ac
    7.5dBi Integrated AP, 5GHz Dual chain with 802.11ac support, 5x Gigabit Ethernet ports
    Compare
    $109.00
    SEXTANT G
    SEXTANT G
    18dBi integrated CPE/Backbone, Gigabit Ethernet
    Compare
    $110.00
    SXT SA5 ac
    SXT SA5 ac
    802.11ac up to 540Mbit, high output, wide beamwidth sector antenna
    Compare
    $119.00
    Metal 52 ac
    Metal 52 ac
    2.4/5GHz software selectable AP/Backbone/CPE with AC support, high TX power, N-male connector, Omni antenna included
    Compare
    $119.00
    OmniTIK 5 PoE ac
    OmniTIK 5 PoE ac
    7.5dBi Integrated AP, 5GHz Dual chain with 802.11ac support, 5x Gigabit Ethernet ports with PoE-out
    Compare
    $129.00
    wAP 60G AP
    wAP 60G AP
    60 GHz Base Station with Phase array 60° beamforming Integrated antenna, 716 Mhz CPU, 256 MB RAM, PSU and PoE, RouterOS L4
    Compare
    $129.00
    SXT LTE kit
    SXT LTE kit
    SXT 2G/3G/4G/LTE CPE, 9dBi 60 degree antenna, 2x Ethernet ports (one with PoE out), two SIM, 650MHz CPU, 64MB RAM, enclosure, PoE and PSU (RouterOS L3), International bands
    Compare
    $129.00
    SXT LTE kit-US
    SXT LTE kit-US
    SXT 3G/4G/LTE CPE, 9dBi 60 degree antenna, 2x Ethernet ports (one with PoE out), two SIM, 650MHz CPU, 64MB RAM, enclosure, PoE and PSU (RouterOS L3), US bands
    Compare
    $129.00
    mANTBox 15s
    mANTBox 15s
    5GHz 120 degree 15dBi dual polarization sector Integrated antenna with 720Mhz CPU, 128MB RAM, SFP, PSU and PoE
    Compare
    $139.00
    SXT 4G kit
    SXT 4G kit NEW
    SXT 4G/LTE CPE, 10.5dBi 60 degree antenna, 2x Ethernet ports (one with PoE out), two SIM and LTE modem for bands 3, 7, 20, 31, 41n, 42 and 43
    Compare
    $139.00
    QRT 2
    QRT 2
    2.4Ghz AP/Backbone/CPE, dual-chain, Gigabit Ethernet
    Compare
    $149.00
    NetMetal 5
    NetMetal 5
    Dual chain 5GHz integrated 802.11a/n/ac AP/Backbone/CPE with an additional miniPCI-e slot, 2xRPSMA connectors, Gigabit Ethernet, waterproof metal enclosure
    Compare
    $149.00
    NetMetal 5SHP
    NetMetal 5SHP
    Dual chain 5GHz integrated 802.11ac AP/Backbone/CPE, 2xRPSMA connectors, high TX power, Gigabit Ethernet, waterproof metal enclosure
    Compare
    $159.00
    NetMetal 5 triple
    NetMetal 5 triple
    Triple chain 5GHz integrated 802.11ac AP/Backbone/CPE with an additional miniPCI-e slot, Gigabit Ethernet, waterproof metal enclosure
    Compare
    $159.00
    LHG LTE kit
    LHG LTE kit NEW
    LHG 2G/3G/4G/LTE High gain 17dBI CPE for very remote areas, International bands
    Compare
    $159.00
    LHG LTE kit-US
    LHG LTE kit-US NEW
    LHG 3G/4G/LTE High gain 17dBI CPE for very remote areas, US bands
    Compare
    $159.00
    QRT 5
    QRT 5
    5GHz AP/Backbone/CPE, dual-chain, Gigabit Ethernet
    Compare
    $169.00
    NetMetal 5SHP triple
    Triple chain 5GHz integrated 802.11ac AP/Backbone/CPE, 3xRPSMA connectors, high power, Gigabit Ethernet, waterproof metal enclosure
    Compare
    $169.00
    LHG 4G kit
    LHG 4G kit NEW
    LHG 4G/LTE High gain 21dBi CPE for very remote areas, LTE modem for bands 3, 7, 20, 31, 41n, 42 and 43
    Compare
    $169.00
    DynaDish 5
    DynaDish 5
    Dual chain 5GHz 802.11a/n/ac QCA9882, 128MB RAM, 720 MHz CPU, 25dBi antenna gain
    Compare
    $179.00
    DynaDish 6
    DynaDish 6
    Dual chain 25dBi Long Range 5.9-6.4GHz Integrated antenna for licensed band
    Compare
    $179.00
    Wireless Wire
    Wireless Wire
    1 Gbps full duplex without cables!
    Compare
    $198.00
    QRT 5 ac
    QRT 5 ac
    Dual chain 5GHz 802.11a/n/ac QCA9882, 128 MB RAM, 720 MHz CPU, 24 DBi antenna gain
    Compare
    $199.00
    mANTBox 19s
    mANTBox 19s
    5GHz 120 degree 19dBi dual polarization sector Integrated antenna with 720Mhz CPU, 128MB RAM, SFP, PSU and PoE
    Compare
    $199.00
    wAP 60Gx3 AP
    wAP 60Gx3 AP NEW
    60 GHz Base Station with Phase array 180° beamforming Integrated antenna, specially designed for Multipoint connections
    Compare
    $199.00
    Wireless Wire Dish
    Wireless Wire Dish
    2 Gb/s aggregate link up to 1500m+ without cables!
    Compare
    $298.00
    Wireless for home and office
    hAP mini
    hAP mini
    Tiny size home 2.4Ghz AP with three LAN ports
    Compare
    $19.95
    hAP lite
    hAP lite
    Low cost home wireless AP with dual chain 2.4GHz wireless, powered by USB
    Compare
    $21.95
    hAP lite TC
    hAP lite TC
    Small home AP with four ethernet ports and a colorful enclosure.
    Compare
    $21.95
    mAP lite
    mAP lite
    Tiny size 2.4GHz Dual Chain access point with a 650MHz CPU, 64MB RAM and one Ethernet
    Compare
    $25.00
    cAP lite
    cAP lite
    Low-cost dual-chain 2.4GHz AP with wall and ceiling enclosure
    Compare
    $29.00
    PWR-Line AP (EU plug)
    PWR-Line AP (EU plug) NEW
    802.11b/g/n WiFi AP with a single Ethernet port and capability to connect to other PWR-LINE devices through the electrical lines in your premises (Type C plug, European)
    Compare
    $42.00
    PWR-Line AP (US plug)
    PWR-Line AP (US plug) NEW
    802.11b/g/n WiFi AP with a single Ethernet port and capability to connect to other PWR-LINE devices through the electrical lines in your premises (Type A plug, US plug)
    Compare
    $42.00
    mAP
    mAP
    Dual-Chain 2.4GHz micro AP, 650MHz CPU, 64MB RAM, 2xEthernet, PoE out
    Compare
    $45.00
    hAP
    hAP
    2.4GHz AP, Five Ethernet ports, PoE-out on port 5, USB for 3G/4G support
    Compare
    $45.00
    wAP
    wAP
    Small weatherproof wireless access point for mounting on a ceiling, wall or pole
    Compare
    $45.00
    wAP BE
    wAP BE
    Small weatherproof wireless access point for mounting on a ceiling, wall or pole. In black
    Compare
    $45.00
    wsAP ac lite
    wsAP ac lite
    In-wall Dual Concurrent 2.4GHz / 5GHz wireless access point with three Ethernet ports and telephone jack pass through for hospitality networks
    Compare
    $49.00
    cAP
    cAP
    Ceiling AP, Dual-Chain 2.4GHz, 650MHz CPU, RouterOS L4, 802.3at/af support
    Compare
    $49.95
    hAP ac lite
    hAP ac lite
    Dual-Concurrent 2.4/5GHz AP, 802.11ac, Five Ethernet ports, PoE-out on port 5, USB for 3G/4G support
    Compare
    $49.95
    hAP ac lite TC
    hAP ac lite TC
    Dual-Concurrent 2.4/5GHz AP, 802.11ac, Five Ethernet ports, PoE-out on port 5, USB for 3G/4G support, universal tower case
    Compare
    $49.95
    RB951Ui-2HnD
    RB951Ui-2HnD
    2.4GHz AP with five Ethernet ports and PoE output on port 5. It has a 600MHz CPU, 128MB RAM and a USB port.
    Compare
    $59.95
    cAP ac
    cAP ac
    Dual-band 2.4 / 5GHz wireless access point for mounting on a ceiling or wall with two Gigabit Ethernet ports (one with PoE output), 802.11ac support and IPsec hardware encryption support
    Compare
    $69.00
    hAP ac²
    hAP ac²
    Dual-Concurrent 2.4/5GHz AP, 802.11a/b/g/n/ac, Five Gigabit Ethernet ports, USB for 3G/4G support, universal tower case and IPsec hardware encryption support
    Compare
    $69.00
    wAP R
    wAP R
    Small weatherproof wireless access point with LTE antennas and miniPCI-e slot
    Compare
    $79.00
    RB951G-2HnD
    RB951G-2HnD
    2.4Ghz AP, 5xGigabit Ethernet, USB, 600MHz CPU, 128MB RAM
    Compare
    $79.95
    wAP ac
    wAP ac
    Small dual-band 2.4 / 5GHz white weatherproof wireless access point for mounting on a ceiling, wall or pole
    Compare
    $89.00
    wAP ac BE
    wAP ac BE
    Small dual-band 2.4 / 5GHz black weatherproof wireless access point for mounting on a ceiling, wall or pole
    Compare
    $89.00
    LtAP mini
    LtAP mini
    Small weatherproof wireless access point with LTE antennas, two SIM slots, integrated GPS and miniPCI-e slot
    Compare
    $89.00
    wAP LTE kit
    wAP LTE kit
    Small weatherproof wireless access point with International LTE modem
    Compare
    $119.00
    wAP LTE kit US
    wAP LTE kit US
    Small weatherproof wireless access point with United States LTE modem
    Compare
    $119.00
    RB2011UiAS-2HnD-IN
    RB2011UiAS-2HnD-IN
    2.4GHz AP, 5x Ethernet, 5x Gigabit Ethernet, SFP cage, USB, LCD, PoE output on Eth10, 600MHz CPU, 128MB RAM
    Compare
    $129.00
    hAP ac
    hAP ac
    Dual concurrent triple chain 2.4/5GHz AP, 802.11ac/a/n/b/g, Five Gigabit Ethernet ports, PoE-out on port 5, SFP, USB for 3G/4G support or storage
    Compare
    $129.00
    LtAP mini LTE kit
    LtAP mini LTE kit
    Small weatherproof wireless access point with International LTE modem, two SIM slots and GPS
    Compare
    $129.00
    LtAP mini LTE kit-US
    Small weatherproof wireless access point with United States LTE modem, two SIM slots and GPS
    Compare
    $129.00
    wAP 4G kit
    wAP 4G kit NEW
    Small weatherproof wireless access point with LTE modem for bands 3, 7, 20, 31, 41n, 42 and 43
    Compare
    $129.00
    LtAP mini 4G kit
    LtAP mini 4G kit NEW
    Small weatherproof wireless access point with LTE modem for bands 3, 7, 20, 31, 41n, 42 and 43, two SIM slots and GPS
    Compare
    $139.00
    RB4011iGS+5HacQ2HnD-IN
    RB4011iGS+5HacQ2HnD-IN NEW
    Powerful 10xGigabit port router with a Quad-core 1.4Ghz CPU, 1GB RAM, SFP+ 10Gbps cage, dual band 2.4GHz / 5GHz 4x4 MIMO 802.11a/b/g/n/ac wireless and desktop case
    Compare
    $249.00
    RouterBOARD
    911 Lite5
    600Mhz CPU, 64MB RAM, 1xEthernet, onboard 5Ghz single chain wireless, RouterOS L3
    Compare
    $39.00
    RBM11G
    Small size powerful OEM board with one Gigabit LAN and one miniPCIe slot
    Compare
    $39.00
    911 Lite5 dual
    600Mhz CPU, 64MB RAM, 1xEthernet, onboard 5Ghz Dual chain wireless, RouterOS L3
    Compare
    $45.00
    RB911G-2HPnD
    600Mhz CPU, 32MB RAM, 1xGigabit Ethernet, onboard 2.4Ghz wireless, RouterOS L3
    Compare
    $49.00
    911 Lite5 ac
    650Mhz CPU, 64MB RAM, 1xEthernet, onboard 5Ghz dual chain wireless with AC, RouterOS L3
    Compare
    $49.00
    RBM33G
    Powerful OEM board with three Gigabit LAN and two miniPCIe slots
    Compare
    $49.00
    RB911G-5HPnD
    600MHz CPU, 32MB RAM, 1xGigabit Ethernet, onboard 5GHz wireless, RouterOS L3
    Compare
    $55.00
    RB912UAG-5HPnD
    600MHz CPU, 64MB RAM, 1xGigabit Ethernet, onboard 5Ghz wireless, miniPCI-express, USB, SIM slot, RouterOS L4
    Compare
    $79.00
    RB912UAG-2HPnD
    600MHz CPU, 64MB RAM, 1xGigabit Ethernet, onboard 2.4Ghz wireless, miniPCI-express, USB, SIM slot, RouterOS L4
    Compare
    $79.00
    RB911G-5HPacD
    720Mhz CPU, 128MB RAM, 1xGigabit Ethernet, onboard 802.11ac Two Chain 5Ghz wireless, RouterOS L3
    Compare
    $79.00
    RB922UAGS-5HPacD
    720Mhz CPU, 128MB RAM, 1xGigabit Ethernet, 1xSFP cage, 1xminiPCI-e, 1xSIM, onboard 802.11ac Two Chain 5Ghz wireless, RouterOS L4
    Compare
    $99.00
    RB450Gx4
    Four core 716MHz CPU, 1GB RAM, 5xGigabit Ethernet, PoE out on port #5, RouterOS L5
    Compare
    $99.00
    RB953GS-5HnT-RP
    720MHz CPU, 128MB RAM, 3x Gigabit Ethernet, 2xSFP cage, built-in 5GHz 3x3 MIMO wireless, 2x miniPCI-e, 2x SIM, USB, 3xRPSMA connectors, RouterOS L5
    Compare
    $169.00
    RB800
    800MHz CPU, 256MB RAM, 3x Gigabit Ethernet, 4x miniPCI, USB, miniPCI-express, daughterboard connector RouterOS L6
    Compare
    $359.00
    Enclosures
    CA411-711
    Black aluminium indoor, fits RB411, RB911, RB912 and RB922 series, set of front panels
    Compare
    $15.00
    CA150
    Black aluminium indoor case that fits the RB450 and RB850 series devices
    Compare
    $19.00
    CA433U
    Black aluminium indoor, Fits RB433 series and RBM33G
    Compare
    $20.00
    CA493
    Black aluminium indoor, Fits RB493 series
    Compare
    $20.00
    Interfaces
    S-85DLC05D
    SFP (1.25G) module, 550m, Multi Mode
    Compare
    $22.00
    S-31DLC20D
    SFP (1.25G) module, 20KM, Single Mode
    Compare
    $29.00
    S+DA0001
    SFP+ direct attach cable, 1m
    Compare
    $29.00
    S-RJ01
    RJ45 SFP 10/100/1000M copper module
    Compare
    $29.00
    R11e-5HnD
    5Ghz miniPCI-express, 802.11a/n dual chain, 2x MMCX
    Compare
    $39.00
    R11e-2HPnD
    2Ghz miniPCI-express, 802.11b/g/n dual chain, 2x MMCX
    Compare
    $39.00
    R11e-2HnD
    2Ghz miniPCI-express, 802.11b/g/n dual chain, 2x u.Fl
    Compare
    $39.00
    S+DA0003
    SFP+ direct attach cable, 3m
    Compare
    $39.00
    S-55DLC80D NEW
    SFP 1.25G module for 80km links with Dual LC-connector
    Compare
    $39.00
    R11e-5HacD
    5Ghz miniPCI-express, 802.11ac/a/n dual chain, 2x MMCX
    Compare
    $49.00
    S-C47DLC40D
    SFP CWDM module 1.25G 40km 1470nm
    Compare
    $49.00
    S-C49DLC40D
    SFP CWDM module 1.25G 40km 1490nm
    Compare
    $49.00
    S-C51DLC40D
    SFP CWDM module 1.25G 40km 1510nm
    Compare
    $49.00
    S-C53DLC40D
    SFP CWDM module 1.25G 40km 1530nm
    Compare
    $49.00
    S-C55DLC40D
    SFP CWDM module 1.25G 40km 1550nm
    Compare
    $49.00
    S-C57DLC40D
    SFP CWDM module 1.25G 40km 1570nm
    Compare
    $49.00
    S-C59DLC40D
    SFP CWDM module 1.25G 40km 1590nm
    Compare
    $49.00
    S-C61DLC40D
    SFP CWDM module 1.25G 40km 1610nm
    Compare
    $49.00
    S+AO0005 NEW
    SFP+ Active Optics direct attach cable, 5m
    Compare
    $49.00
    R5SHPn
    5Ghz miniPCI 802.11a/n single chain, MMCX connector
    Compare
    $59.00
    S+85DLC03D
    SFP+ (10Gbit), 300m, Multi Mode
    Compare
    $59.00
    R11e-5HacT
    5Ghz miniPCI-e, 802.11ac/a/n tripple chain, 3x MMCX
    Compare
    $59.00
    R52HnD
    2.4/5Ghz miniPCI 802.11a/b/g/n dual chain, 2x MMCX
    Compare
    $59.00
    S+RJ10 NEW
    6-speed RJ-45 module for up to 10 Gbps
    Compare
    $65.00
    R11e-LTE-US
    LTE miniPCI-e card for United States bands
    Compare
    $69.00
    R11e-LTE
    LTE miniPCI-e card for International bands
    Compare
    $75.00
    S-3553LC20D
    Two SFP (1.25G) module kit, 20Km, single mode
    Compare
    $79.00
    R11e-4G NEW
    LTE miniPCI-e card for bands 3,7,20,31,41n,42,43
    Compare
    $79.00
    S-4554LC80D NEW
    Pair of SFP 1.25G module for 80km links with Single LC-connectors
    Compare
    $89.00
    S+31DLC10D
    SFP+ (10Gbit) module, Long range 10km, Single Mode
    Compare
    $149.00
    S+C47DLC10D
    SFP+ CWDM module 10G 10km 1470nm
    Compare
    $199.00
    S+C49DLC10D
    SFP+ CWDM module 10G 10km 1490nm
    Compare
    $199.00
    S+C51DLC10D
    SFP+ CWDM module 10G 10km 1510nm
    Compare
    $199.00
    S+C53DLC10D
    SFP+ CWDM module 10G 10km 1530nm
    Compare
    $199.00
    S+C55DLC10D
    SFP+ CWDM module 10G 10km 1550nm
    Compare
    $199.00
    S+C57DLC10D
    SFP+ CWDM module 10G 10km 1570nm
    Compare
    $199.00
    S+C59DLC10D
    SFP+ CWDM module 10G 10km 1590nm
    Compare
    $199.00
    S+C61DLC10D
    SFP+ CWDM module 10G 10km 1610nm
    Compare
    $199.00
    S+2332LC10D
    pair of SFP+ (10Gbit) modules, 10km, for single optical cable
    Compare
    $349.00
    CWDM-MUX8A
    Combine up to eight fiber links into one
    Compare
    $359.00
    Accessories
    RBPOE
    PoE injector, for 10/100Mbps products
    Compare
    $5.00
    K-65 NEW
    Rackmount ears for RB4011 series
    Compare
    $5.00
    QM
    Basic wall mount adapter for small point to point and sector antennas
    Compare
    $5.50
    RBGPOE
    PoE injector, for Gigabit LAN products
    Compare
    $8.00
    ACMMCXRPSMA
    MMCX to RPSMA pigtail
    Compare
    $8.00
    ACOMNIRPSMA
    2.4Ghz 5dBi Dipole antenna with RPSMA connector
    Compare
    $8.00
    RB2011 Wall Mount Kit
    Wall mount kit for RB2011 desktop series, Protects cables, Powder coated steel
    Compare
    $8.95
    18POW
    24V 0.8A Power adapter
    Compare
    $9.00
    Flex-guide
    Low loss cable assembly, soldered on both ends, with silver plated copper and less than 0.65dB losses
    Compare
    $9.00
    ACSMAUFL
    U.fl - SMA female pigtail for wAP R
    Compare
    $9.00
    SMASMA
    1m SMA male to SMA male cable
    Compare
    $9.00
    ACGPSA
    Active GPS antenna for LtAP mini LTE Kit
    Compare
    $9.00
    DINrail PRO NEW
    DIN rail mounting bracket for LtAP mini series
    Compare
    $9.00
    QMP
    Advanced wall mount adapter for small point to point and sector antennas
    Compare
    $9.50
    QME
    Advanced wall mount adapter for large point to point and sector antennas
    Compare
    $9.50
    QMP-LHG
    Advanced wall mount adapter for LHG
    Compare
    $9.50
    RB4011 wall mount kit NEW
    A simple solution for mounting the RB4011 in public locations to avoid accidental unplugging of cables.
    Compare
    $12.00
    ACSWIM
    2.4/5Ghz Omni antenna, 4dBi gain, MMCX connector
    Compare
    $15.00
    LHG mount NEW
    Basic pole mount adapter for LHG series, made from metal
    Compare
    $15.00
    Woobm-USB
    The Wireless out of band management USB stick
    Compare
    $16.00
    24HPOW
    24V 2.5A adapter
    Compare
    $18.00
    48POW
    48V 1.46A 70W power adapter
    Compare
    $18.00
    RBGPOE-CON-HP
    48 to 24V 10/100/1000Mbps PoE converter 802.3af support, 802.3at PoE plus support
    Compare
    $24.95
    mUPS
    PoE injector with battery backup capability
    Compare
    $29.00
    solidMOUNT NEW
    An advanced pole mount adapter for LHG series products
    Compare
    $29.00
    RBFTC11
    Fiber to Copper converter, Outdoor case, 12-57V PoE with 802.3af/at support
    Compare
    $39.00
    48V2A96W
    48 V 2 A 96 W power supply with plug
    Compare
    $39.00
    CWDM-CHASSIS-2
    1U Chassis bracket for CWDM MUX/DEMUX
    Compare
    $49.00
    12POW150
    Hot Swap power supply for CCR1072
    Compare
    $100.00
    PW48V-12V150W
    Hot Swap -48V DC telecom power supply for CCR1072
    Compare
    $100.00
    Antennas
    mANT LTE 5o
    5dBi LTE antenna with 2 x SMA connectors
    Compare
    $19.00
    MTA Radome Kit
    Radome Cover Kit for mANT, reduces wind load, increases antenna operational life
    Compare
    $39.00
    mANT 15s
    Dual-polarization 5Ghz 15dBi 120 degree beamwidth antenna with two RP-SMA connectors
    Compare
    $49.00
    Sleeve30
    Sleeve30 kit for our mANT30 parabolic antenna to enhance point-to-point link performance
    Compare
    $89.00
    mANT 19S
    Dual-polarization 5Ghz 19dBi 120 degree beamwidth antenna with two RP-SMA connectors
    Compare
    $99.00
    mANT30
    Parabolic dish antenna for 5GHz, 30dBi gain
    Compare
    $119.00
    mANT30 PA
    Parabolic dish antenna for 5GHz, 30dBi gain. This model includes precision alignment mount
    Compare
    $129.00
