Skip to main content
Chateau 5G R17 ax
Get online instantly – even without a SIM card. The iconic MikroTik 5G home router gets its smartest upgrade yet... full eSIM support!
4x Gbit ethernet ports
Quad-core 1.8 GHz ARM CPU
1x 2.5 Gbit ethernet
MicroSIM & eSIM
Blazing fast Release 17 5G modem
4x4 MIMO
Video thumbnail
More speed. More bands. More flexibility.
Chateau 5G ax R17 may look familiar – the sleek design, the mighty dual-band Wi-Fi 6 coverage, and all the impressive RouterOS v7 features. But under the hood, everything’s been pushed further.
Now powered by 5G Release 17 cutting-edge modem, Chateau takes full advantage of the latest mobile technologies, including advanced carrier aggregation combinations. That means faster downlink speeds, increased signal stability and responsiveness, even in regions where the mobile tower is far away. Wherever you are, Chateau finds the signal sweet spot.
Your network, your rules: eSIM or microSIM
Chateau has a true embedded SIM (eSIM) built right in, fully compatible with
MikroTik Connectivity
Third-party eSIMs
Multiple eSIM profiles
FAQ
How do I activate the eSIM?
Wait, so I can use any eSIM, including my current mobile operator, not just MikroTik Connectivity?
What is the purpose of MikroTik Connectivity then?
Wireless that actually delivers
With four powerful built-in LTE/5G antennas and two external dual-chain Wi-Fi 6 antennas, Chateau gives you great performance for download and upload even in a busy, crowded environment:
Background image
Smart aggregation with wide regional FDD + TDD band support
Extra strong signal pickup thanks to 4x4 MIMO
Wi-Fi coverage designed for homes of all sizes, including multi-floor setups.
For secure remote work, play, and everything in between
Chateau runs RouterOS v7, MikroTik’s industrial-grade operating system used by ISPs and sysadmins around the world – but with a simple user-friendly interface that anyone can learn to use. And if you’re not sure about diving deep into the world of networking – no worries, we also have iOS/Android app for even easier installation!
Set up a secure VPN. Optimize streaming. Limit bandwidth. Create VLANs. Block sites. Send SMS alerts when usage peaks. All without subscriptions or paywalls.
Chateau 5G ax R17 is perfect for:
  • Remote workers who need fast, reliable, secure LTE/5G internet
  • Mobile operators looking for modern, simple, affordable TR-069 device management
  • Households tired of plastic “black box” routers that limit what they can do
  • Anyone ready to ditch slow DSL or patchy Wi-Fi extenders
Chateau 5G R17 ax
Product image
Product image
Product image
Product image thumbnail
Specification
Specifications
  • Product code S53UG+5HaxD2HaxD-TC&RG650E-EU
  • Suggested price $349.00
  • Architecture ARM 64bit
  • CPU IPQ-6010
  • CPU core count 4
  • CPU nominal frequency 864-1800 MHz
  • CPU Threads count 4
  • Switch chip model IPQ-6010
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 1 GB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • Number of DC inputs 1 (DC jack)
  • DC jack input Voltage 12-28 V
  • Max power consumption 27 W
  • Max power consumption without attachments 18 W
  • Cooling type Passive
Mobile
  • 3G Category R8 (42.2Mbps Downlink, 5.76Mbps Uplink)
  • 3G bands 1 (2100MHz)
    5 (850MHz)
    8 (900MHz)
  • LTE Category 20 (2.0 Gbps Downlink, 211 Mbps Uplink)
  • MIMO DL 4x4
  • MIMO UL 1x1 (5G SA MIMO UL 2x2)
  • LTE FDD bands 1 (2100MHz)
    3 (1800MHz)
    5 (850MHz)
    7 (2600MHz)
    8 (900 MHz)
    20 (800MHz)
    28 (700MHz)
    32 (1500 MHz)
  • LTE TDD bands 38 (2600MHz)
    40 (2300MHz)
    41 (2500MHz)
    42 (3500MHz)
    43 (3700MHz)
  • 5G NSA FDD bands 1 (2100 MHz)
    3 (1800 MHz)
    5 (850 MHz)
    7 (2600 MHz)
    8 (900 MHz)
    20 (800 MHz)
    26 (850 MHz)
    28 (700 MHz)
    67 (700 MHz)
    75 (1500 MHz)
    76 (1500 MHz)
  • 5G NSA TDD bands 38 (2600 MHz)
    40 (2300 MHz)
    41 (2500 MHz)
    77 (3700 MHz)
    78 (3500 MHz)
  • 5G SA FDD bands 1 (2100 MHz)
    3 (1800 MHz)
    5 (850 MHz)
    7 (2600 MHz)
    8 (900 MHz)
    20 (800 MHz)
    26 (850 MHz)
    28 (700 MHz)
    67 (700 MHz)
    75 (1500 MHz)
    76 (1500 MHz)
  • 5G SA TDD bands 38 (2600 MHz)
    40 (2300 MHz)
    41 (2500 MHz)
    77 (3700 MHz)
    78 (3500 MHz)
  • TAC 86896506
Wireless specifications
  • Wireless 2.4 GHz Max data rate 574 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n/ax
  • Antenna gain dBi for 2.4 GHz 3
  • Wireless 2.4 GHz chip model QCN-5022
  • Wireless 2.4 GHz generation Wi-Fi 6
  • Wireless 5 GHz Max data rate 1200 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n/ac/ax
  • Antenna gain dBi for 5 GHz 6
  • Wireless 5 GHz chip model QCN-5052
  • Wireless 5 GHz generation Wi-Fi 6
Ethernet
  • 10/100/1000 Ethernet ports 4
  • Number of 2.5G Ethernet ports 1
Peripherals
  • Number of SIM slots 1 Modem (Micro SIM)
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1.5
Other
  • CPU temperature monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Mode button Yes
  • eSIM Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP 20
Included parts
Note
Wireless Specification
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25 download files for arm64 devices.
System Package
Default Packages
More in download page
