Skip to main content
CRS112-8P-4S-IN
8x Gigabit Ethernet Smart Switch with PoE-out, 4x SFP cages, 400MHz CPU, 128MB RAM, desktop case, RouterOS L5
PoE
SFP/SFP+
CRS112-8P-4S-IN
Product image
Product image
Product image thumbnail
CRS112-8P-4S-IN is an eight Gigabit RJ45 port PoE switch, that offers different power output options: autosensing 802.3af/at PoE/PoE+ and Passive PoE, and four SFP ports provide optical fiber connectivity options to support uplinks of up to 1 Gbps.
CRS112-8P-4S-IN is equipped with 12 independent switching ports. 28 V 3.4 A power supply is already included in the box. There is secondary DC jack on the back of the enclosure that supports 48-57 V power supply (not included, can be purchased separately - product codes 48POW (1.46A 70W) and 48V2A96W (2A 96W)). CRS112-8P-4S-IN can power 802.3af/at devices if 48-57 V DC input is used (unit will automatically detect and provide correct power to devices). Max current is 1 A per port if input voltage is 18-28 V, 450 mA if 48-57 V. Total limit is 2.8A@24V and 1.4A@48-57V. PoE-Out is passed over mode B 4,5 (+) and 7,8 (-) pins
Specification
Specifications
  • Product code CRS112-8P-4S-IN
  • Suggested price $209.00
  • Architecture MIPSBE
  • CPU QCA8511
  • CPU core count 1
  • CPU nominal frequency 400 MHz
  • Switch chip model QCA8511
  • Dimensions 200 x 142 x 44 mm
  • RouterOS license 5
  • Operating System RouterOS
  • Size of RAM 128 MB
  • Storage size 16 MB
  • Storage type FLASH
  • Tested ambient temperature -20°C to 60°C
Powering
  • Number of DC inputs 2 (DC jack)
  • DC jack input Voltage 18-28 V / 48-57 V
  • Max power consumption 160 W
  • Max power consumption without attachments 10 W
  • Cooling type Passive
PoE-out
  • PoE-out ports Ether1-Ether8
  • PoE out 802.3af/at
  • Low voltage PoE-Out current limit 1 A
  • High voltage PoE-Out current limit 450 mA
  • Max total out (A) 2.8A (18V-28V) & 1.4A (48V-57V) A
Ethernet
  • 10/100/1000 Ethernet ports 8
  • Number of 1G Ethernet ports with PoE-out 8
Fiber
  • SFP ports 4
Peripherals
  • Serial console port RJ45
Other
  • PCB temperature monitor Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP20
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
System Package
More in download page
