Industrial temperature grade (-40°C to +85°C) SFP 1.25G module with Dual LC connector for long distance 80km links. Compatible with all MikroTik products, that have SFP or SFP+ cages.
Send purchase questions| Details | |
| Product code | S-55DLC80D |
| Connector | Dual LC UPC |
| Data Rate | 1.25G |
| Distance | 80km |
| Format | SFP |
| MTBF | Approximately 100'000 hours at 25C |
| Mode | SM |
| Tested ambient temperature | -40 to +70C |
| Wavelength | 1550nm |
| Suggested price | $39 |
Download: Full CE declaration (PDF)
Information about S-55DLC80D
| [BG] Bulgarian | С настоящето, "Mikrotikls SIA", декларира, че S-55DLC80D е в съответствие със съществените изисквания и другитеприложими разпоредби на Директива 2014/53/EC. |
| [CZ] Czech | "Mikrotikls SIA" tímto prohlašuje, že S-55DLC80D splňuje základní požadavky a všechna příslušná ustanoveni Směrnice 2014/53/ES. |
| [DK] Danish | Undertegnede "Mikrotikls SIA" erklærer herved, at følgende udstyr S-55DLC80D overholder de væsentlige krav og øvrige relevante krav i direktiv 2014/53/EF. |
| [DE] German | Hiermit erklärt "Mikrotikls SIA", dass sich das Gerät S-55DLC80D in Übereinstimmung mit den grundlegenden Anforderungen und den übrigen einschlägigen Bestimmungen der Richtlinie 2014/53/EG befindet. |
| [EE] Estonian | Käesolevaga kinnitab "Mikrotikls SIA" seadme S-55DLC80D vastavust direktiivi 2014/53/EÜ põhinõuetele ja nimetatud direktiivist tulenevatele teistele asjakohastele sätetele. |
| [GR] Greek | ΜΕ ΤΗΝ ΠΑΡΟΥΣΑ Ο ΚΑΤΑΣΚΕΥΑΣΤΗΣ "Mikrotikls SIA" ΔΗΛΩΝΕΙ ΟΤΙ S-55DLC80D ΣΥΜΜΟΡΦΩΝΕΤΑΙ ΠΡΟΣ ΤΙΣ ΟΥΣΙΩΔΕΙΣ ΑΠΑΙΤΗΣΕΙΣ ΚΑΙ ΤΙΣ ΛΟΙΠΕΣ ΣΧΕΤΙΚΕΣ ΔΙΑΤΑΞΕΙΣ ΤΗΣ ΟΔΗΓΙΑΣ 2014/53/ΕΚ |
| [EN] English | Hereby, "Mikrotikls SIA", declares that this S-55DLC80D is in compliance with the essential requirements and other relevant provisions of Directive 2014/53/EC. |
| [ES] Spanish | Por la presente, "Mikrotikls SIA", declara que este S-55DLC80D cumple con los requisitos esenciales y otras exigencias relevantes de la Directiva 2014/53/EC. |
| [IT] Italian | Con la presente "Mikrotikls SIA" dichiara che questo S-55DLC80D è conforme ai requisiti essenziali ed alle altre disposizioni pertinenti stabilite dalla direttiva 2014/53/CE. |
| [LV] Latvian | Ar šo "Mikrotikls SIA" deklarē, ka S-55DLC80D atbilst Direktīvas 2014/53/EK būtiskajām prasībām un citiem ar to saistītajiem noteikumiem. |
| [LT] Lithuanian | Šiuo "Mikrotikls SIA" deklaruoja, kad šis S-55DLC80D atitinka esminius reikalavimus ir kitas 2014/53/EB Direktyvos nuostatas |
| [HU] Hungarian | A "Mikrotikls SIA" ezzennel kijelenti, hogy a S-55DLC80D típusú beren-dezés teljesíti az alapvető követelményeket és más 2014/53/EK irányelvben meghatározott vonatkozó rendelkezéseket. |
| [NL] Dutch | Hierbij verklaart "Mikrotikls SIA" dat het toestel l S-55DLC80D in overeenstemming is met de essentiële eisen en de andere relevante bepalin-gen van richtlijn 2014/53/EG. |
| [PL] Polish | Niniejszym "Mikrotikls SIA" deklaruje że S-55DLC80D jest zgodny z zasadniczymi wymaganiami i innymi właściwymi postanowieniami Dyrektywy 2014/53/EC. |
| [PT] Portuguese | Eu, "Mikrotikls SIA", declaro que o S-55DLC80D cumpre os requisitos essenciais e outras provisões relevantes da Directiva 2014/53/EC. |
| [RO] Romanian | Prin prezenta, "Mikrotikls SIA", declară că aparatul S-55DLC80D este în conformitate cu cerinţele esenţiale şi cu alte prevederi pertinente ale Directivei 2014/53/CE.. |
| [SK] Slovak | "Mikrotikls SIA" týmto vyhlasuje, že S-55DLC80D spĺňa základné požiadavky a všetky príslušné ustanovenia Smernice 2014/53/ES. |
| [SI] Slovenian | "Mikrotikls SIA" izjavlja, da je ta S-55DLC80D v skladu z bistvenimi zahtevami in drugimi relevantnimi določili direktive 2014/53/ES. |
| [FI] Finish | "Mikrotikls SIA" vakuuttaa täten että S-55DLC80D tyyppinen laite on direktiivin 2014/53/EY oleellisten vaatimusten ja sitä koskevien direktiivin muiden ehtojen mukainen. |
| [SE] Swedish | Denna utrustning är i överensstämmelse med de väsentliga kraven och andra relevanta bestämmelser i direktiv 2014/53/EC. |
| [NO] Norwegian | "Mikrotikls SIA", Erklærer herved at S-55DLC80D er i samsvar med de grunnleggende krav og øvrige relevante krav i direktiv 2014/53/EF. |
