Skip to main content
Discontinued
RB2011iLS-IN
Desktop metal case, 5xEthernet, 5xGigabit Ethernet, SFP cage, PoE out on port 10, 600MHz CPU, 64MB RAM, RouterOS L4
PoE
SFP/SFP+
RB2011iLS-IN
Product image
Product image thumbnail
RB2011iLS is our first product with SFP cage for gigabit SFP transceivers and ideal solution for FTTH (Fiber To The Home) implementations.
The RB2011iLS has 11 ports: Gigabit SFP cage and five Gigabit Ethernet ports that can be switched together providing affordable wirespeed Fiber-to-Copper converter, and additional five Fast Ethernet ports. Board can be powered by power jack or PoE.
Note that SFP transceiver is NOT included. RB2011iLS supports any 1.25G SFP transceivers that is within the SFF Committee specifications for SFP Transceivers. RB2011LS doesn’t have hardware support for PON (Passive Optical Network).
Tested and recommended to use with MikroTik SFP modules: S-85DLC05D, S-31DLC20D and S-35/53LC20D (not included)
It’s powered by the new Atheros next generation 600MHz 74K MIPS network processor and has 64MB of RAM and a Level4 RouterOS license.
There is PoE output function for port #10 - it can power other PoE capable devices with the same voltage as applied to the unit. Maximum load on the port is 500mA.
RouterBOARD 2011iLS-IN comes with desktop enclosure and power supply.
Wall mount kit for network closet is available for purchase as an optional accessory.
Specification
Specifications
  • Product code RB2011iLS-IN
  • Suggested price $109.00
  • Architecture MIPSBE
  • CPU AR9344
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • Switch chip model AR8327-BL1A-R
  • Dimensions 230x90x25mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -35C to +65C
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 8-30 V
  • Max power consumption 18 W
  • Max power consumption without attachments 6 W
  • PoE in Passive PoE
  • PoE in input Voltage 8-30 V
PoE-out
  • PoE-out ports Ether10
  • PoE out Passive PoE
  • Low voltage PoE-Out current limit 510 mA
  • Max total out (A) 510 mA
Ethernet
  • 10/100 Ethernet ports 5
  • 10/100/1000 Ethernet ports 5
Fiber
  • SFP DDMI Yes
  • SFP ports 1
Other
  • Beeper Yes
Included parts
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for mipsbe devices.
System Package
More in download page
