Skip to main content
hEX S
5x Gigabit Ethernet, SFP, Dual Core 880MHz CPU, 256MB RAM, USB, microSD, RouterOS L4, IPsec hardware encryption support and The Dude server package
PoE
SFP/SFP+
hEX S
Product image
Product image
Product image
Product image
Product image thumbnail
hEX S is a five port Gigabit Ethernet router for locations where wireless connectivity is not required. Compared to the hEX, the hEX S also features an SFP port and PoE output on the last port.
It is affordable, small and easy to use, but at the same time comes with a very powerful dual core 880 MHz CPU and 256 MB RAM, capable of all the advanced configurations that RouterOS supports. The device has a USB 2.0, PoE output for Ethernet port #5 and a 1.25Gbit/s SFP cage. The port #5 can power other passive PoE capable devices with the same voltage as applied to the unit
IPsec hardware encryption and The Dude server package is supported, microSD slot on it provides improved r/w speed for file storage and Dude.
Specification
Specifications
  • Product code RB760iGS
  • Suggested price $79.00
  • Architecture MMIPS
  • CPU MT7621A
  • CPU core count 2
  • CPU nominal frequency 880 MHz
  • CPU Threads count 4
  • Switch chip model MT7621A
  • Dimensions 113 x 89 x 28 mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 256 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 12-57 V
  • Max power consumption 24 W
  • Max power consumption without attachments 6 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 12-57 V
PoE-out
  • PoE-out ports Ether5
  • PoE out Passive PoE up to 57V
  • Low voltage PoE-Out current limit 500 mA
  • High voltage PoE-Out current limit 500 mA
  • Max total out (A) 500 mA
Ethernet
  • 10/100/1000 Ethernet ports 5
Fiber
  • SFP ports 1
Peripherals
  • Memory card type microSD
  • Memory Cards 1
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Mode button Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP20
Included parts
Note
Ethernet test results
IPsec test results
Documents
Download
Latest RouterOS stable release v7.24.5 download files for mmips devices.
System Package
More in download page
