Skip to main content
Discontinued
CCR1016-12S-1S+
1U rackmount, 12xSFP cage, 1xSFP+ cage, 16 cores x 1.2GHz CPU, 2GB RAM, LCD panel, Dual Power supplies, RouterOS L6
SFP/SFP+
CCR1016-12S-1S+
Product image
Product image
Product image thumbnail
CCR1016 is an industrial grade router with a cutting edge 16 core Tilera CPU. If you need many millions of packets per second - Cloud Core Router is your best choice.
This model has twelve SFP ports and one SFP+ port for 10G connectivity. It is available in a 1U rackmount case and also has a serial console port, a touchscreen LCD and a USB port.
The CCR1016-12S-1S+ comes with redundant power supplies and one RJ45 SFP 10/100/1000M copper module.
Specification
Specifications
  • Product code CCR1016-12S-1S+
  • Suggested price $815.00
  • Architecture TILE
  • CPU TLR4-01680
  • CPU core count 16
  • CPU nominal frequency 1.2 GHz
  • CPU Threads count 16
  • Dimensions 443 x 197 x 44 mm
  • RouterOS license 6
  • Operating System RouterOS
  • Size of RAM 2 GB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -20°C to 60°C
Powering
  • Number of AC inputs 2
  • AC input range 100-240
  • Max power consumption 47.5 W
  • Max power consumption without attachments 34 W
  • Cooling type 2 fans
Fiber
  • SFP DDMI Yes
  • SFP ports 12
  • SFP+ ports 1
Peripherals
  • Memory card type microSD
  • Memory Cards 1
  • Serial console port RJ45
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • CPU temperature monitor Yes
  • PCB temperature monitor Yes
  • Mode button Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP20
Included parts
Note
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for tile devices.
More in download page
