Skip to main content
CRS312-4C+8XG-RM
Switch of the future: the first MikroTik product with 10G RJ45 Ethernet ports and SFP+
Combo ports
Dual boot
10G
ROS v7
CRS312-4C+8XG-RM
Product image
Product image thumbnail
Remove the bottleneck from your network setup – it is time to upgrade that 1 Gigabit switch to something truly powerful and enjoy real speed. Introducing CRS312-4C+8XG-RM – our first product with 10G RJ45 Ethernet ports. Moreover, it also has 4 x 10G combo ports: use them for 10G RJ45 Ethernet or 10G SFP+, when you need an additional fiber connection. Combo ports can be used alongside the 8 regular 10G RJ45 Ethernet ports at all times. These ports can also be software selected, so you can use RouterOS scripting, to decide which combo ports will be active.
This device is a practical solution for those who work with huge data files and need fast, capable connection 24/7: multimedia production, scientific research, game development, big data analysis and so on. CRS312-4C+8XG-RM has a dual power supply for redundancy – no unexpected downtime when the deadlines are looming. It has a full size USB, a console port for configuration and a 1U rackmount case – fits all the standard racks.
You can choose between our legendary feature-packed RouterOS for booting or a simpler, but still powerful SwOS. If you would like the ability to use routing and other Layer 3 features in your CRS, use RouterOS.
This switch has a great total non-blocking throughput of 120 Gbps, switching capacity of 240 Gbps and forwarding rate of 178 Mpps. CRS312-4C+8XG-RM – built for professionals, great for everyone!
Specification
Specifications
  • Product code CRS312-4C+8XG-RM
  • Suggested price $699.00
  • Architecture MIPSBE
  • CPU QCA9531
  • CPU core count 1
  • CPU nominal frequency 650 MHz
  • Switch chip model 98DX8212
  • Dimensions 443 x 183 x 44 mm
  • RouterOS license 5
  • Operating System RouterOS v7 / SwitchOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
  • Tested ambient temperature -30°C to 70°C
Powering
  • Number of AC inputs 2
  • AC input range 100-240
  • Frequency (Hz) 50-60
  • Max power consumption 60 W
  • Cooling type 4 fans
Ethernet
  • 10/100 Ethernet ports 1
  • Number of Combo 10G Ethernet/ SFP+ ports 4
  • Number of 1G/2.5G/5G/10G Ethernet ports 8
Peripherals
  • Serial console port RJ45
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • Voltage Monitor Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP 20
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
Latest SwitchOS release v2.19 download files for css312 devices.
More in download page
