Skip to main content
Discontinued
CRS212-1G-10S-1S+IN
Smart Switch, 1x Gigabit LAN, 10x SFP cages, 1x SFP+ cage, LCD, 400MHz CPU, 64MB RAM, Metal desktop case, RouterOS L5
SFP/SFP+
CRS212-1G-10S-1S+IN
Product image
Product image thumbnail
Cloud Router Switch 212-1G-10S-1S+IN is new “small size low cost” member of our CRS series. It comes with one Gigabit Ethernet RJ45 port, ten SFP cages and one 10G SFP+ cage, as well as LCD panel and serial port (RJ45). Product includes indoor desktop case and power supply. Special ears are provided for mounting the unit in rack.
Our CRS series combines the best features of a fully functional router and a Layer 3 switch, is powered by the familiar RouterOS. All the specific Switch configuration options are available in a special Switch menu, but if you want, ports can be removed from the switch configuration, and used for routing purposes.
Specification
Specifications
  • Product code CRS212-1G-10S-1S+IN
  • Suggested price $219.00
  • Architecture MIPSBE
  • CPU QCA8519
  • CPU core count 1
  • CPU nominal frequency 400 MHz
  • Switch chip model QCA8519
  • Dimensions 200 x 142 x 44 mm
  • RouterOS license 5
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 1 (DC jack)
  • DC jack input Voltage 8-30 V
  • Max power consumption 20 W
  • Cooling type 1 fan
Ethernet
  • 10/100/1000 Ethernet ports 1
Fiber
  • SFP ports 10
  • SFP+ ports 1
Peripherals
  • Serial console port RJ45
Other
  • Current Monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
System Package
More in download page
