Skip to main content
CRS305-1G-4S+IN
Five-port desktop switch with one Gigabit Ethernet port and four SFP+ 10Gbps ports
ARM
Dual boot
PoE
SFP/SFP+
CRS305-1G-4S+IN
Product image
Product image
Product image
Product image thumbnail
The CRS305 is a compact yet very powerful switch, featuring four SFP+ ports, for up to 10 Gbit per port. The device has a 1 Gbit copper ethernet port for management access or regular traffic forwarding and two DC jacks for power redundancy. The device is a very sleek and compact metallic case without any fans, for silent operation.
The device has a “Dual boot” feature that allows you to choose between two operating systems - RouterOS or SwOS. If you prefer to have a simplified operating system with only switch specific features, use SwOS. If you would like the ability to use routing and other Layer 3 features in your CRS, use RouterOS. You can select the desired operating system from RouterOS, from SwOS or from the RouterBOOT loader settings. All the feature set comes with a disruptive price, providing the best price/performance on the market.
Specification
Specifications
  • Product code CRS305-1G-4S+IN
  • Suggested price $149.00
  • Architecture ARM 32bit
  • CPU 98DX3236
  • CPU core count 2
  • CPU nominal frequency 800 MHz
  • Switch chip model 98DX3236
  • Dimensions 141 x 115 x 28 mm
  • RouterOS license 5
  • Operating System RouterOS / SwitchOS
  • Size of RAM 512 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 3 (DC jack, PoE-IN)
  • DC jack input Voltage 12-57 V
  • Max power consumption 18 W
  • Max power consumption without attachments 10 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 12-57 V
Ethernet
  • 10/100/1000 Ethernet ports 1
Fiber
  • SFP+ ports 4
Other
  • CPU temperature monitor Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP20
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for arm devices.
Latest SwitchOS release v2.19 download files for css305 devices.
More in download page
