Skip to main content
RB4011iGS+5HacQ2HnD-IN
Powerful 10xGigabit port router with a Quad-core 1.4Ghz CPU, 1GB RAM, SFP+ 10Gbps cage, dual band 2.4GHz / 5GHz 4x4 MIMO 802.11a/b/g/n/ac wireless and desktop case
ARM
Quad-core CPU
Mini PCI-e
PoE
ROS v7
SFP/SFP+
Dual-band
Product image
Product image
Product image
Product image
Product image thumbnail
RB4011 series - amazingly powerful routers with ten Gigabit ports, SFP+ 10Gbps interface and IPsec hardware acceleration for a great price!
The RB4011 uses a quad core Cortex A15 CPU, same as in our carrier grade RB1100AHx4 unit. The unit is equipped with 1GB of RAM, can provide PoE output on port #10 and comes with a compact and professional looking solid metal enclosure in matte black.
RB4011iGS+5HacQ2HnD-IN (WiFi model) is dual band, four chain unit with a supported data rate of up to 1733 Mbps in 5GHz. For legacy devices, the unit also has a dual chain 2GHz wireless card installed in miniPCI-e slot.
We have two versions available.
RB4011iGS+5HacQ2HnD-IN-US (USA) is factory locked for 2412-2462MHz, 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
RB4011iGS+5HacQ2HnD-IN (International) supports 2412-2484MHz and 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
Specification
Specifications
  • Product code RB4011iGS+5HacQ2HnD-IN
  • Suggested price $275.00
  • Architecture ARM 32bit
  • CPU AL21400
  • CPU core count 4
  • CPU nominal frequency auto (533 - 1900) MHz
  • CPU Threads count 4
  • Switch chip model RTL8367SB
  • Dimensions 228 x 120 x 30 mm
  • RouterOS license 5
  • Operating System RouterOS v7
  • Size of RAM 1 GB
  • Storage size 512 MB
  • Storage type NAND
  • Tested ambient temperature -40°C to 45°C
Wireless capabilities
  • Wireless 5 GHz Max data rate 1733 Mbit/s
  • Wireless 5 GHz Number of chains 4
  • Wireless 5 GHz standards 802.11a/n/ac
  • Antenna gain dBi for 5 GHz 3
  • Wireless 5 GHz chip model QCA9984
  • Wireless 5 GHz generation Wi-Fi 5
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 3
  • Wireless 2.4 GHz chip model R11e-2HnD
  • Wireless 2.4 GHz generation Wi-Fi 4
  • WiFi speed AC2000
Ethernet
  • 10/100/1000 Ethernet ports 10
Fiber
  • SFP+ ports 1
Peripherals
  • MiniPCI-e slots 1
  • Serial console port RJ45
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 12-57 V
  • Max power consumption 44 W
  • Max power consumption without attachments 23 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 18-57 V
PoE-out
  • PoE-out ports Ether10
  • PoE out Passive PoE up to 57V
  • Low voltage PoE-Out current limit 600 mA
  • High voltage PoE-Out current limit 420 mA
  • Max total out (A) 600 mA
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP20
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
Included parts
Note
Wireless Specification
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for arm devices.
System Package
Default Packages
More in download page
