Skip to main content
Discontinued
RB4011 wall mount kit
A simple solution for mounting the RB4011 in public locations to avoid accidental unplugging of cables.
Product image
Product image
Product image thumbnail
The RB4011 wall mount kit is made for protecting your device and it’s ethernet ports from unauthorised access. Made from durable steel, the mount attaches to a wall and allows the ethernet cables to be plugged in, before the router is mounted inside. This means that once the device is secured, there is no easy way to unplug cables, or move the device.
Specification
Specifications
  • Product code WMK4011
  • Suggested price $12.00
Documents
Brochure
.PDF
Brochure PDF first page
