Skip to main content
hAP ac
Dual concurrent triple chain 2.4/5GHz AP, 802.11ac/a/n/b/g, Five Gigabit Ethernet ports, PoE-out on port 5, SFP, USB for 3G/4G support or storage
PoE
ROS v7
SFP/SFP+
Dual-band
hAP ac
Product image
Product image thumbnail
The hAP ac is our most universal home or office wireless device. It is a dual band device with Gigabit ports that allow the full advantages of 802.11ac technology speed, while maintaining compatibility with legacy devices in 2GHz 802.11 b/g/n and 5GHz a/n modes.
The omnidirectional antennas allow to mount the hAP ac in any location, and the high power transmitter will ensure good coverage for the mobile devices in your home, office or public location.
Other helpful features include a USB port for attaching extra storage or a 3G/4G modem, PoE output on the last Ethernet port, to power other RouterBOARD devices without needing an extra power adapter and an SFP cage, for connecting active or passive optical network modules.
We have two versions available.
- RB962UiGS-5HacT2HnT-US (USA) is factory locked for 2412-2462MHz, 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
- RB962UiGS-5HacT2HnT (International) supports 2412-2484MHz and 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
Specification
Specifications
  • Product code RB962UiGS-5HacT2HnT
  • Suggested price $129.00
  • Architecture MIPSBE
  • CPU QCA9558
  • CPU core count 1
  • CPU nominal frequency 720 MHz
  • Switch chip model QCA8337
  • Dimensions 114 x 137 x 29mm
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 128 MB
  • Storage size 16 MB
  • Storage type FLASH
Wireless capabilities
  • Wireless 2.4 GHz Max data rate 450 Mbit/s
  • Wireless 2.4 GHz Number of chains 3
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 2.5
  • Wireless 2.4 GHz chip model QCA9558
  • Wireless 2.4 GHz generation Wi-Fi 4
  • Wireless 5 GHz Max data rate 1300 Mbit/s
  • Wireless 5 GHz Number of chains 3
  • Wireless 5 GHz standards 802.11a/n/ac
  • Antenna gain dBi for 5 GHz 2
  • Wireless 5 GHz chip model QCA9880
  • Wireless 5 GHz generation Wi-Fi 5
  • WiFi speed AC1750
Ethernet
  • 10/100/1000 Ethernet ports 5
Fiber
  • SFP ports 1
Peripherals
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 11-57 V
  • Max power consumption 17 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 11-57 V
PoE-out
  • PoE-out ports Ether5
  • PoE out Passive PoE
  • Low voltage PoE-Out current limit 700 mA
  • High voltage PoE-Out current limit 350 mA
  • Max total out (A) 700 mA
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP20
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for mipsbe devices.
Default Packages
More in download page
