Skip to main content
Discontinued
mANTBox 52 15s
A dual-band 2.4/5 GHz base station with a powerful built-in sector antenna, PoE support, Gigabit Ethernet and SFP. One powerful package for all your outdoor network needs, perfect for camps, stadiums and parks!
ARM
Quad-core CPU
IP 55
Outdoors
PoE
SFP/SFP+
Dual-band
mANTBox 52 15s
Product image
Product image
Product image
Product image thumbnail
Are you managing an outdoor wireless network with a variety of access points and CPE devices? Then our brand new mANTBox 52 15s has got you covered – offering powerful built-in antennas, fascinating connectivity options and more!
Creating an efficient point-to-multipoint connection used to be tricky, but not anymore: mANTBox 52 15s works well in any setup. The dual-band wireless capability allows you to use both 2.4 GHz and 5 GHz devices at the same time. There is a Gigabit Ethernet port and an SFP port for fiber connections.
We have doubled the RAM and added a new quad-core CPU that can handle even the heaviest loads. mANTBox 52 15s can even provide IPsec hardware offloading without trouble. Depending on the rest of your setup, you can reach distance up to 20 km with the built-in dual polarization antenna.
Video thumbnail
Specification
Specifications
  • Product code RBD22UGS-5HPacD2HnD-15S
  • Suggested price $179.00
  • Architecture ARM 32bit
  • CPU IPQ-4019
  • CPU core count 4
  • CPU nominal frequency auto MHz
  • CPU Threads count 4
  • Switch chip model IPQ-4019
  • Dimensions 140 x 348 x 82 mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 256 MB
  • Storage size 16 MB
  • Storage type FLASH
  • Tested ambient temperature -40°C to +70°C
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 12-57 V
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 12-57 V
Wireless specifications
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 12
  • Wireless 2.4 GHz chip model IPQ-4019
  • Wireless 2.4 GHz generation Wi-Fi 4
  • Wireless 5 GHz Max data rate 867 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n/ac
  • Antenna gain dBi for 5 GHz 15
  • Wireless 5 GHz chip model IPQ-4019
  • Wireless 5 GHz generation Wi-Fi 5
Ethernet
  • 10/100/1000 Ethernet ports 1
Fiber
  • SFP ports 1
Peripherals
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP55
Included parts
Note
Wireless Specification
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for arm devices.
System Package
More in download page
