Skip to main content
Discontinued
CRS109-8G-1S-2HnD-IN
8x Gigabit Smart Switch, 1x SFP cage, LCD, 802.11b/g/n Dual Chain wireless, 600MHz CPU, 128MB RAM, Metal desktop case, RouterOS L5, supports 10-57V.
PoE
SFP/SFP+
Product image
Product image thumbnail
Cloud Router Switch 109-8G-1S-2HnD-IN is new "small size low cost" member of our CRS series. It comes with eight Gigabit Ethernet ports and high power 2.4GHz wireless. Product supports 10-57V.
Our CRS series combines the best features of a fully functional router and a Layer 3 switch, is powered by the familiar RouterOS. All the specific Switch configuration options are available in a special Switch menu, but if you want, ports can be removed from the switch configuration, and used for routing purposes.
Specification
Specifications
  • Product code CRS109-8G-1S-2HnD-IN
  • Suggested price $149.00
  • Architecture MIPSBE
  • CPU AR9344
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • Switch chip model QCA8511
  • Dimensions 200 x 142 x 44 mm
  • RouterOS license 5
  • Operating System RouterOS
  • Size of RAM 128 MB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -40°C to 65°C
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 10-57 V
  • Max power consumption 13 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 10-57 V
Wireless specifications
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 4
  • Wireless 2.4 GHz chip model AR9344
  • Wireless 2.4 GHz generation Wi-Fi 4
Ethernet
  • 10/100/1000 Ethernet ports 8
Fiber
  • SFP DDMI yes
  • SFP ports 1
Peripherals
  • Serial console port RJ45
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type microUSB type AB
  • Max USB current (A) 1.5
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, FCC, EAC, ROHS
  • IP IP20
Included parts
Note
Wireless Specification
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
System Package
More in download page
