Skip to main content
Discontinued
CCR1036-8G-2S+EM
1U rackmount, 8x Gigabit Ethernet, 2xSFP+ cages, LCD, 36 cores x 1.2GHz CPU, 8GB RAM, 41.5mpps fastpath, Up to 28Gbit/s throughput, RouterOS L6, Dual PSU
M.2
SFP/SFP+
CCR1036-8G-2S+EM
Product image
Product image
Product image thumbnail
Our fastest router has now become even better - the new CCR1036-8G-2S+ now has two SFP+ ports for 10G interface support (SFP+ module available separately). It uses the same 36 core Tilera CPU as our other CCR1036 model, and delivers the same performance, but now, ten gigabit links are possible.
The device comes in a 1U rackmount case, has two SFP+ ports, eight Gigabit ethernet ports and a serial console port.
The new version of CCR1036-8G-2S+EM has onboard 8GB of RAM, onboard M.2 slot, full size USB slot and dual PSU for redundancy!
Supports both SFP (1.25G) and SFP+ (10G) modules
Specification
Specifications
  • Product code CCR1036-8G-2S+EM
  • Suggested price $1,395.00
  • Architecture TILE
  • CPU TLR4-03680
  • CPU core count 36
  • CPU nominal frequency 1.2 GHz
  • CPU Threads count 36
  • Dimensions 443 x 193 x 44 mm
  • RouterOS license 6
  • Operating System RouterOS
  • Size of RAM 8 GB
  • Storage size 1 GB
  • Storage type NAND
  • Tested ambient temperature -20°C to 60°C
Powering
  • Number of AC inputs 2
  • AC input range 100-240
  • Max power consumption 73 W
  • Cooling type 2 fans
Ethernet
  • 10/100/1000 Ethernet ports 8
Fiber
  • SFP DDMI Yes
  • SFP+ ports 2
Peripherals
  • Memory card type microSD
  • Memory Cards 1
  • Serial console port RJ45
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
  • Number of M.2 slots 1
Other
  • CPU temperature monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Mode button Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP20
Included parts
Note
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for tile devices.
More in download page
