Skip to main content
Discontinued
CCR1009-7G-1C-1S+PC
7x Gigabit Ethernet, 1x Combo port (SFP or Gigabit Ethernet), 1xSFP+ cage, 9 cores x 1GHz CPU, 2GB RAM, LCD panel, passive cooling desktop enclosure, SmartCard slot, RouterOS L6, PSU
Combo ports
PoE
SFP/SFP+
CCR1009-7G-1C-1S+PC
Product image
Product image
Product image thumbnail
The new updated revision of CCR1009 is here. We attempted to combine all the customer feedback and best practice in CCR device manufacturing that we learned over the last three years, since the first CCR1009 devices were launched.
Important changes
No switch-chip - the device now features only fully independent Ethernet ports each with a direct connection to the CPU, allowing to overcome previous shared 1Gbit limitation from switch-chip ports and utilize full potential of CPU processing power on those ports.
Combo-port - a single 1Gbit software interface that has two hardware interfaces - an SFP cage and a Gigabit Ethernet port, allowing you to use any type of connection available to you. It is also possible to switch between both physical interfaces in RouterOS. In an event of disconnect the combo-port provides hardware fail-over feature.
100Mbps SFP support - this is our first device that supports 100BASE-LX/100BASE-SX/100BASE-BX fiber modules, as well as standard 1.25G SFP modules.
More throughput - because the ports are now directly connected to the CPU, the new CCR1009 can achieve even higher throughput.
This unit is equipped with passive cooling enclosure, two heat-pipes and a specially designed heat-sink, so its completely silent. It’s powered by an external 24V 2.5A AC/DC adapter and supports power redundancy if you also power it from the PoE input port.
Unit also includes a LCD touchscreen, smart card slot, microSD and a SFP+ port for 10G connections.
Specification
Specifications
  • Product code CCR1009-7G-1C-1S+PC
  • Suggested price $545.00
  • Architecture TILE
  • CPU TLR4-00980
  • CPU core count 9
  • CPU nominal frequency 1 GHz
  • CPU Threads count 9
  • Dimensions 272 x 190 x 44 mm
  • RouterOS license 6
  • Operating System RouterOS
  • Size of RAM 2 GB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -20°C to 60°C
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 18-57 V
  • Max power consumption 38 W
  • Max power consumption without attachments 33 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 18-57 V
Ethernet
  • 10/100/1000 Ethernet ports 7
  • Ethernet Combo ports 1
Fiber
  • SFP+ ports 1
Peripherals
  • Number of SIM slots 1 Smart card (Mini SIM)
  • Memory card type microSD
  • Memory Cards 1
  • Serial console port RS232
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type microUSB type AB
  • Max USB current (A) 1
Other
  • CPU temperature monitor Yes
  • Current Monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP20
Included parts
Note
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for tile devices.
More in download page
