Skip to main content
Discontinued
RB953GS-5HnT-RP
720MHz CPU, 128MB RAM, 3x Gigabit Ethernet, 2xSFP cage, built-in 5GHz 3x3 MIMO wireless, 2x miniPCI-e, 2x SIM, USB, 3xRPSMA connectors, RouterOS L5
Mini PCI-e
Outdoors
PoE
SFP/SFP+
RB953GS-5HnT-RP
Product image
Product image
Product image thumbnail
RouterBOARD 953GS-5HnT-RP is our first product with 5GHz 3x3 MIMO Triple Chain support. It has a powerful Atheros QCA9558 CPU 802.11a/n wireless support with three RPSMA connectors.
RB953GS-5HnT is equipped with a new Scorpion 720Mhz CPU, 128MB RAM and three Gigabit Ethernet ports, to take advantage of high-speed 3x3 MIMO wireless. Moreover, it comes with two SFP cages to accommodate FTTH and fiber ring requirements.
Handy additions are two miniPCI-express slots and two SIM slots, for multiple 3G/4G connections or wireless expansion.
Unit comes with preinstalled RouterOS Level5 license.
- RB953GS-5HnT-RP-US (USA) is factory locked for 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
- RB953GS-5HnT-RP (International) supports 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
Specification
Specifications
  • Product code RB953GS-5HnT-RP
  • Suggested price $169.00
  • Architecture MIPSBE
  • CPU QCA9558
  • CPU core count 1
  • CPU nominal frequency 720 MHz
  • Switch chip model AR8327
  • Dimensions 183x105x24mm
  • RouterOS license 5
  • Operating System RouterOS
  • Size of RAM 128 MB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 11-30 V
  • Max power consumption 25 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 11-30 V
Wireless specifications
  • Wireless 5 GHz Max data rate 450 Mbit/s
  • Wireless 5 GHz Number of chains 3
  • Wireless 5 GHz standards 802.11a/n
  • Wireless 5 GHz chip model QCA9558
  • Wireless 5 GHz generation Wi-Fi 4
Ethernet
  • 10/100/1000 Ethernet ports 3
Fiber
  • SFP ports 2
Peripherals
  • Number of SIM slots 2 Modem (Mini SIM)
  • MiniPCI-e slots 2
  • Serial console port RS232
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
More in download page
