Skip to main content
New
R11e-LTE7
An easy drop-in upgrade for RouterBOARD integrators. This miniPCIe CAT7 modem delivers up to 300 Mbps with Band 28 & 32 support and carrier aggregation for better rural performance. Fully compatible with RouterOS v7 devices such as LtAP and RBM33G – upgrade your LTE speed without changing your setup.
LTE Cat7
Outdoors
R11e-LTE7
Product image
Product image thumbnail
The next-generation miniPCIe LTE CAT7 modem for your RouterBOARDs. Drop-in replacement for FG621-EA – now offering 300 Mbps down / 100 Mbps up, with added Band 32 & Band 28 support.
Perfect for LtAP, RBM33G, or any system with miniPCIe or USB (if you’re using an adapter). Compared to the previous FG621 version, this miniPCIe unit has a smaller form-factor, so it should fit better inside more devices. Upgrade your mobile connectivity without changing the whole setup!
Specification
Specifications
  • Product code R11e-LTE7
  • Suggested price $65.00
  • Tested ambient temperature -10°C to 55°C
Powering
  • Max power consumption 5 W
Mobile
  • 3G Category R8 (DL: 42.2 Mbps; UL: 5.76 Mbps)
  • 3G bands 1 (2100MHz)
    5 (850MHz)
    8 (900MHz)
    3 (1800 MHz)
  • LTE Category 7 (DL: 300 Mbps; UL: 100 Mbps)
  • MIMO DL 2x2
  • MIMO UL 1x1
  • LTE FDD bands 1 (2100MHz)
    3 (1800MHz)
    5 (850MHz)
    7 (2600MHz)
    8 (900 MHz)
    20 (800MHz)
    28 (700MHz)
    32 (1500 MHz)
  • LTE TDD bands 38 (2600MHz)
    40 (2300MHz)
    41 (2500MHz)
  • TAC 35312597
Certification & Approvals
  • Certification CE, ROHS
  • IP 00
Note
Documents
Brochure
.PDF
Brochure PDF first page
