Skip to main content
RB922UAGS-5HPacD
720Mhz CPU, 128MB RAM, 1xGigabit Ethernet, 1xSFP cage, 1xminiPCI-e, 1xSIM, onboard 802.11ac Two Chain 5Ghz wireless, RouterOS L4
Mini PCI-e
Outdoors
PoE
SFP/SFP+
RB922UAGS-5HPacD
Product image
Product image thumbnail
RouterBOARD RB922UAGS-5HPacD is a very versatile wireless router, perfect for assembling your own solution. It supports the new 802.11ac standard for high speed wireless (up to 866Mbit datarate and 20/40/80MHz channels). The device has ports and slots for many uses: 1x SFP cage, miniPCIe slot with SIM for 3G/4G modem or another wireless card, USB port, Gigabit Ethernet port and two MMCX connectors for the built in powerful 802.11ac 2x2 radio. Comes with RouterOS L4 (AP) license.
- RB922UAGS-5HPacD-US (USA) is factory locked for 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
- RB922UAGS-5HPacD (International) supports 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
Specification
Specifications
  • Product code RB922UAGS-5HPacD
  • Suggested price $99.00
  • Architecture MIPSBE
  • CPU QCA9557
  • CPU core count 1
  • CPU nominal frequency 720 MHz
  • Dimensions 105x105mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 128 MB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 8-30 V
  • Max power consumption 17 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 8-30 V
Wireless specifications
  • Wireless 5 GHz Max data rate 867 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n/ac
  • Wireless 5 GHz chip model QCA9882
  • Wireless 5 GHz generation Wi-Fi 5
Ethernet
  • 10/100/1000 Ethernet ports 1
Fiber
  • SFP DDMI yes
  • SFP ports 1
Peripherals
  • Number of SIM slots 1 Modem (Mini SIM)
  • MiniPCI-e slots 1
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP00
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
System Package
Default Packages
More in download page
