Skip to main content
R11e-2HnD
2Ghz miniPCI-express, 802.11b/g/n dual chain, 2x u.Fl
Outdoors
R11e-2HnD
Product image
Product image thumbnail
R11e-2HnD is a Low-profile Lower power version of our 2.4Ghz miniPCIe card - it has a small heat-sink, u.Fl connector and less output power. Low profile is useful if you need to install the card in device like a laptop.
Specification
Specifications
  • Product code R11e-2HnD
  • Suggested price $39.00
  • Tested ambient temperature -40C to +65C
  • Storage size 4 KB
  • Storage type FLASH
Powering
  • Max power consumption 4.6 W
Wireless specifications
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Wireless 2.4 GHz chip model AR9582
  • Wireless 2.4 GHz generation Wi-Fi 4
Certification & Approvals
  • Certification FCC, IC
Wireless Specification
Documents
Brochure
.PDF
Brochure PDF first page
