Skip to main content
Discontinued
LtAP 4G kit
A heavy-duty 2.4GHz access point with extra miniPCI-e slot, three SIM slots, GNSS support (GPS, GLONASS, BeiDou, Galileo) and LTE modem for International bands 3, 7, 20, 31, 41n, 42 and 43
Automotive
IP 54
LTE Cat4
Mini PCI-e
Outdoors
PoE
LtAP 4G kit
Product image
Product image
Product image
Product image
Product image
Product image thumbnail
Introducing LtAP 4G kit – a heavy-duty 4G (LTE) access point with GPS support.
The new LtAP 4G kit is a compact 4G (LTE) capable weatherproof wireless access point – perfect for busy urban environment or off-the-grid outdoors networking. It has a built-in cellular modem that supports 4G (LTE) connectivity – no need for additional devices, it works out of the box.
Its high power 2.4 GHz 802.11b/g/n wireless capability provides secure access to LTE network from your phone or any other wireless device with up to 150 Mbps download speed. You can also use a Gigabit Ethernet LAN port for your wired devices. There are several power options – DC jack, POE-in and automotive.
The rugged and extremely durable case with a special wall mounting kit will be perfect for almost any challenge: from public transportation, food trucks or logistics to harsh winter and stormy desert environment. LtAP can handle any temperature from -40 C‎° to +70 C‎°. It is a perfect solution for tracking vehicles in real time. We have provided a simple tracking application example in the RouterOS documentation to help you get started. LtAP even has 3 Mini-SIM slots for easy roaming management. Saves your time and money worldwide!
The unit comes with an extra miniPCIe slot, offering many expansion options. For example, you can install a second LTE modem for redundancy or a 5GHz interface to have dual concurrent 2.4 GHz / 5GHz AP + LTE. Another miniPCIe slot is already populated with the LTE modem.
LtAP has a RS232 serial port, which gives you console access for debugging, as well as full size USB for other devices.
RBLtAP-2HnD&R11e-4G includes LTE modem that supports International bands 3, 7, 20, 31, 41n, 42 and 43.
The new LtAP 4G kit is more than an access point – it is what you need it to be wherever you need it to be.
Specification
Specifications
  • Product code RBLtAP-2HnD&R11e-4G
  • Suggested price $179.00
  • Architecture MMIPS
  • CPU MT7621A
  • CPU core count 2
  • CPU nominal frequency 880 MHz
  • CPU Threads count 4
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 128 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 3 (DC jack, PoE-IN, Automotive)
  • DC jack input Voltage 12-30 V
  • Automotive input Voltage 12-27 V
  • Max power consumption 24 W
  • Max power consumption without attachments 12 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 12-30 V
Mobile
  • LTE Category 4 (150Mbps Downlink, 50Mbps Uplink)
  • LTE FDD bands 3 (1800MHz)
    7 (2600MHz)
    20 (800MHz)
    31 (450MHz)
  • LTE TDD bands 41n (2500MHz)
    42 (3500MHz)
    43 (3700MHz)
  • TAC 35914709
Wireless specifications
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 2.5
  • Wireless 2.4 GHz chip model AR9382
  • Wireless 2.4 GHz generation Wi-Fi 4
Ethernet
  • 10/100/1000 Ethernet ports 1
Peripherals
  • Number of SIM slots 3 Modem (Mini SIM)
  • MiniPCI-e slots 2
  • Serial console port RS232
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • GNSS standards GPS
Certification & Approvals
  • Certification CE, FCC, IC, E-MARK, EAC, ROHS
  • IP IP54
Included parts
Note
Wireless Specification
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25 download files for mmips devices.
System Package
More in download page
