Skip to main content
Discontinued
R11e-5HacT
5Ghz miniPCI-e, 802.11ac/a/n tripple chain, 3x MMCX
Outdoors
R11e-5HacT
Product image
Product image thumbnail
The new AC standard is here, with up to 1.3Gbps datarate and 256-QAM modulation, and 80MHz channels. 802.11ac opens up new possibilities and speeds never possible before.
R11e-5HacT is our first MIMO 3x3 triple chain 802.11ac card in miniPCIe format, perfect for any RouterBOARD with miniPCIe slot, such as RB953, RB912, RB800, BaseBox etc.
The card features built-in LED indicators for wireless mode, connection status (connected, searching, disabled), TX and RX activity and wireless signal strength - just looking at the card will help with installation and alignment.
Specification
Specifications
  • Product code R11e-5HacT
  • Suggested price $59.00
  • Storage size 4 KB
  • Storage type FLASH
Powering
  • Max power consumption 5 W
Wireless specifications
  • dBi
  • 5GHz yes
  • Wireless 5 GHz Max data rate 1300 Mbit/s
  • Wireless 5 GHz Number of chains 3
  • Wireless 5 GHz standards 802.11a/n/ac
  • Wireless 5 GHz chip model QCA9880
  • Wireless 5 GHz generation Wi-Fi 5
Certification & Approvals
  • Certification FCC, IC
  • IP IP00
Wireless Specification
Documents
Brochure
.PDF
Brochure PDF first page
