Skip to main content
R11e-5HnD
5Ghz miniPCI-express, 802.11a/n dual chain, 2x MMCX
Outdoors
R11e-5HnD
Product image
Product image thumbnail
High power 4920-5920MHz 802.11a/n dual chain wireless card in miniPCI-e format. Ideally suited for the new RB912 series, RB800 or our new miniPCIe adapter card - RB14e.
The card features built-in LED indicators for wireless mode, connection status (connected, searching, disabled), TX and RX activity and wireless signal strength - just looking at the card will help with installation and alignment.
Specification
Specifications
  • Product code R11e-5HnD
  • Suggested price $39.00
  • Tested ambient temperature -40C to +65C
  • Storage size 4 KB
  • Storage type FLASH
Wireless specifications
  • 5GHz yes
  • Wireless 5 GHz Max data rate 300 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz chip model AR9582
  • Wireless 5 GHz generation Wi-Fi 4
Certification & Approvals
  • Certification FCC, IC
Wireless Specification
Documents
Brochure
.PDF
Brochure PDF first page
