Skip to main content
Discontinued
CRS112-8G-4S-IN
8x Gigabit Ethernet Smart Switch, 4x SFP cages, 400MHz CPU, 128MB RAM, desktop case, RouterOS L5
PoE
SFP/SFP+
CRS112-8G-4S-IN
Product image
Product image
Product image thumbnail
Cloud Router Switch 112-8G-4S-IN is a “small size low cost” member of our CRS series. It comes with eight Gigabit Ethernet ports and four SFP cages.
Our CRS series combines the best features of a fully functional router and a Layer 3 switch, is powered by the familiar RouterOS.
All the specific Switch configuration options are available in a special Switch menu, but if you want, ports can be removed from the switch configuration, and used for routing purposes.
Specification
Specifications
  • Product code CRS112-8G-4S-IN
  • Suggested price $153.00
  • Architecture MIPSBE
  • CPU QCA8511
  • CPU core count 1
  • CPU nominal frequency 400 MHz
  • Switch chip model QCA8511-AL1C
  • Dimensions 200x143x44mm
  • RouterOS license 5
  • Operating System RouterOS
  • Size of RAM 128 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 10-57 V
  • Max power consumption 10 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 10-57 V
Ethernet
  • 10/100/1000 Ethernet ports 8
Fiber
  • SFP ports 4
Peripherals
  • Serial console port RJ45
Other
  • Current Monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Mode button Yes
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
System Package
More in download page
