Skip to main content
CRS354-48G-4S+2Q+RM
Best price and best performance on the market – this 48 port switch will rock any setup, including 40 Gbps devices!
Dual boot
40G
ROS v7
SFP/SFP+
CRS354-48G-4S+2Q+RM
Product image
Product image
Product image
Product image thumbnail
If you are looking for a single switch that will put your network setup ahead of the curve without costing a fortune, look no further. The new CRS354-48G-4S+2Q+RM is an effective and adaptable rackmount solution for managing networks in demanding and busy environments. With this product we aim to set a new price-performance bar – get more features while spending way less!
This powerful switch has 48 x 1G RJ45 ports and 4 x 10G SFP+ ports. There are also 2 x 40G QSFP+ ports for extremely fast fiber connections or linking with other 40 Gbps devices. The total non-blocking throughput is 168 Gbps, switching capacity is 336 Gbps and the forwarding rate reaches 235 Mpps.
Specification
Specifications
  • Product code CRS354-48G-4S+2Q+RM
  • Suggested price $599.00
  • Architecture MIPSBE
  • CPU QCA9531
  • CPU core count 1
  • CPU nominal frequency 650 MHz
  • Switch chip model 98DX3257
  • Dimensions 297 x 443 x 44 mm
  • RouterOS license 5
  • Operating System RouterOS v7 / SwitchOS
  • Size of RAM 128 MB
  • Storage size 32 MB
  • Storage type FLASH
  • Tested ambient temperature -20°C to 60°C
Powering
  • Number of AC inputs 2
  • AC input range 100-240
  • Number of PSU slots 2
  • Frequency (Hz) 50-60
  • Max power consumption 60 W
  • Max power consumption without attachments 50 W
  • Cooling type 3 fans
Ethernet
  • 10/100 Ethernet ports 1
  • 10/100/1000 Ethernet ports 48
Fiber
  • SFP+ ports 4
  • Number of 40G QSFP+ ports 2
Peripherals
  • Serial console port RJ45
Other
  • CPU temperature monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP20
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for mipsbe devices.
Latest SwitchOS release v2.19 download files for css354 devices.
More in download page
