Skip to main content
Discontinued
mANTBox 19s
5GHz 120 degree 19dBi dual polarization sector Integrated antenna with 720Mhz CPU, 128MB RAM, SFP, PSU and PoE
Outdoors
PoE
SFP/SFP+
mANTBox 19s
Product image
Product image
Product image
Product image thumbnail
The mANTBox is based on our new mANT sector antennas, but also has a wireless router built right in. Powered by the RB921 device, the mANTBox comes ready to use with everything included. The device uses a high speed 720MHz CPU and has a built in 802.11 ac/a/n wireless device with up to 31dBm output power.
mANTBox 19s comes with 19dBi 120 degree sector antenna.
We have two versions available - RB921GS-5HPacD-19S (International) and RB921GS-5HPacD-19S-US (USA). RB921GS-5HPacD-19S-US (USA) is factory locked for 5.17 - 5.25 GHz and 5.725 - 5.835 GHz frequencies. This lock can not be removed. RB921GS-5HPacD-19S (International) supports 5.17 - 5.835 GHz range (Specific frequency range can be limited by country regulations).
Specification
Specifications
  • Product code RB921GS-5HPacD-19S
  • Suggested price $199.00
  • Architecture MIPSBE
  • CPU QCA9557
  • CPU core count 1
  • CPU nominal frequency 720 MHz
  • Dimensions 152 x 598 x 78 mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 128 MB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 8-30 V
  • Max power consumption 13 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 12-28 V
Wireless specifications
  • Wireless 5 GHz Max data rate 867 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n/ac
  • Antenna gain dBi for 5 GHz 19
  • Wireless 5 GHz chip model QCA9892
  • Wireless 5 GHz generation Wi-Fi 5
Ethernet
  • 10/100/1000 Ethernet ports 1
Fiber
  • SFP ports 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
Included parts
Note
Wireless Specification
Ethernet test results
Download
Latest RouterOS stable release v7.25.1 download files for mipsbe devices.
System Package
More in download page
