Skip to main content
Discontinued
CCR1072-1G-8S+
1U rackmount, 1x Gigabit Ethernet, 8xSFP+ cages, LCD, 72 cores x 1GHz CPU, 16GB RAM, up to 120 million packets per second, 80Gbps throughput, RouterOS L6
M.2
SFP/SFP+
CCR1072-1G-8S+
Product image
Product image
Product image
Product image
Product image thumbnail
Our new flagship router, the CCR1072, is powered by a Tilera 72 core CPU, each core is clocked at 1GHz, and to fully utilize this power, the CCR1072 is equipped with eight independently connected 10G SFP+ ports and single Ethernet port for management purposes.
The unit comes equipped with installed RouterOS L6, 16GB of built in ECC RAM, touchscreen color LCD, two removable (hotplug) power supplies for redundancy, smart card slot, microUSB, regular size USB, microSD and 2x M.2 slots for additional storage.
Thanks to the unique 72 core processor and ports that are directly connected to the CPU, CCR1072 is capable of over 120 million packets per second throughput.
Specification
Specifications
  • Product code CCR1072-1G-8S+
  • Suggested price $3,350.00
  • Architecture TILE
  • CPU TLR4-07280
  • CPU core count 72
  • CPU nominal frequency 1 GHz
  • CPU Threads count 72
  • Dimensions 443 x 315 x 44 mm
  • RouterOS license 6
  • Operating System RouterOS
  • Size of RAM 16 GB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -20°C to 60°C
Powering
  • Number of AC inputs 2
  • AC input range 100-240
  • Max power consumption 125 W
  • Cooling type 4 fans
Ethernet
  • 10/100/1000 Ethernet ports 1
Fiber
  • SFP+ ports 8
Peripherals
  • Memory card type microSD, 2x M.2
  • Memory Cards 3
  • Serial console port RJ45
  • Number of USB ports 2
  • USB Power Reset Yes
  • USB slot type microUSB type AB; USB type A
  • Max USB current (A) 1
  • Smart card slot Yes
  • Number of M.2 slots 2
Other
  • CPU temperature monitor Yes
  • Current Monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
Included parts
Note
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for tile devices.
More in download page
