Skip to main content
RB951Ui-2HnD
2.4GHz AP with five Ethernet ports and PoE output on port 5. It has a 600MHz CPU, 128MB RAM and a USB port.
PoE
RB951Ui-2HnD
Product image
Product image thumbnail
The RB951Ui-2HnD is a wireless SOHO AP with a new generation Atheros CPU and more processing power. It has five Ethernet ports, one USB 2.0 port and a high power 2.4GHz 802.11b/g/n wireless AP with antennas built in.
It has a 600MHz CPU,128MB of RAM and PoE output function for port #5 - it can power other PoE capable devices with the same voltage as applied to the unit. Maximum load on the port is 500mA.
Package contains RouterBOARD 951Ui-2HnD in a plastic case and power adapter.
Specification
Specifications
  • Product code RB951Ui-2HnD
  • Suggested price $59.95
  • Architecture MIPSBE
  • CPU AR9344
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • Dimensions 113x138x29mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 128 MB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -20C +60C
Wireless capabilities
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 2.5
  • Wireless 2.4 GHz chip model AR9344
  • Wireless 2.4 GHz generation Wi-Fi 4
Ethernet
  • 10/100 Ethernet ports 5
Peripherals
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 8-30 V
  • Max power consumption 24 W
  • Max power consumption without attachments 7 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 8-30 V
PoE-out
  • PoE-out ports Ether5
  • PoE out Passive PoE
  • Low voltage PoE-Out current limit 500 mA
  • Max total out (A) 500 mA
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP20
Other
  • Beeper Yes
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for mipsbe devices.
Default Packages
More in download page
