Skip to main content
Discontinued
Wireless Wire
1 Gbps full duplex without cables!
ARM
Quad-core CPU
IP 55
Outdoors
PoE
Wireless Wire
Product image
Product image
Product image
Product image
Product image thumbnail
The Wireless Wire is a ground breaking solution which offers fiber speed and quality for a fraction of the price. This amazing kit replaces your Gigabit ethernet cable with two small devices that connect to each other over a 60 GHz wireless link.
Simply point the included devices at one another and power them on, it will make a 1 Gbit full duplex link to instantly replace your cable - this is why we call it the Wireless Wire!
The Wireless Wire makes secure AES encrypted 60 GHz wireless link that is not affected by the crowded WiFi spectrum, offering a stable and fast link for distances of 200 meters or more. The box includes two wAP60G devices that are already paired together, a wall mounting kit, straps for pole mounting and also a pair of table stands for using the devices indoors. The link will even work through most windows, depending on their material.
Specification
Specifications
  • Product code RBwAPG-60adkit
  • Suggested price $228.00
  • Architecture ARM 32bit
  • CPU IPQ-4019
  • CPU core count 4
  • CPU nominal frequency 448-896 (auto) MHz
  • CPU Threads count 4
  • Dimensions 185 x 85 x 30 mm
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 256 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 12-57 V
  • Max power consumption 5 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 12-57 V
Ethernet
  • 10/100/1000 Ethernet ports 1
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP55
Included parts
Note
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for arm devices.
System Package
More in download page
Related Products
