Skip to main content
Cube 60Pro ac
A powerful point-to-point 60 GHz 802.11ay CPE for bridging distances up to 2.4 km.
ARM
Quad-core CPU
GPS
IP 66
Outdoors
PoE
Cube 60Pro ac
Product image
Product image
Product image
Product image thumbnail
Long gone are the days when you had to rely on cables for speed and stability. 60 GHz solutions offer fiber-like speed and stability - while saving you plenty of time and money on installation and maintenance. Our latest Cube 60Pro product line is taking the advantages of 60 GHz networking to the next level – with the 802.11ay standard for even higher distances, stability, speed, and convenience.
The Cube 60Pro ac CPE allows you to establish ultra-fast point-to-point connections over distances as far as 1 km. And that’s not all – we have added Channel 5* support, so you can reach even higher distances if necessary. In our tests, the Cube 60Pro ac easily maintained a reliable connection over 2.4 km. Bridging two locations has never been easier!
You can get a preconfigured kit of two Cube 60Pro ac devices: the Wireless Wire Cube Pro. Just point the Cubes at one another and power them on! They will form a blazing fast encrypted wireless connection. Pure plug-and-play!
Forget about downtime with the automatic 5 GHz backup connection
The 60 GHz frequency is unaffected by the crowded wireless spectrum, it offers high speed and capacity. But it can sometimes struggle during bad weather conditions. That’s why both Cube 60Pro devices feature an automatic 5 GHz failover. We have added a powerful directional antenna so that the 5 GHz range can keep up with the 60 GHz.
More durability, less unwanted attention
We have upgraded the enclosure to feature a strong metal base – for better mounting and cooling options. The Cube form-factor emerges from pure practicality: it is durable, unobtrusive, and compact.
* Use in accordance with local laws and regulations!
Video thumbnail
Specification
Specifications
  • Product code CubeG-5ac60ay
  • Suggested price $149.00
  • Architecture ARM 32bit
  • CPU IPQ-4019
  • CPU core count 4
  • CPU nominal frequency 448-896 (auto) MHz
  • CPU Threads count 4
  • Dimensions 115 x 95 x 82 mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 256 MB
  • Storage size 64 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 10 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 18-57 V
Wireless specifications
  • Wireless 5 GHz Max data rate 433 Mbit/s
  • Wireless 5 GHz Number of chains 1
  • Wireless 5 GHz standards 802.11a/n/ac
  • Antenna gain dBi for 5 GHz 11.5
  • Wireless 5 GHz chip model IPQ4019
  • Wireless 5 GHz generation Wi-Fi 5
Ethernet
  • 10/100/1000 Ethernet ports 1
Other
  • GNSS standards GPS
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP 66
Included parts
Note
Wireless Specification
Ethernet test results
Download
Latest RouterOS stable release v7.24.5 download files for arm devices.
System Package
Default Packages
More in download page
