Skip to main content
New
R11e-LR8G
Enables LoRa® connectivity via miniPCIe in various MikroTik setups. Enhanced 868MHz Rx sensitivity for effective long-range communication ensures reliable long-range communication, built-in GPS.
Outdoors
R11e-LR8G
Product image
Product image thumbnail
The simplest way to add LoRa® connectivity to any MikroTik device with a mini PCIe slot. Perfect for tight budgets without compromising performance, this card features:
  • Enhanced 868MHz Rx sensitivity for effective long-range communication, ensuring reliable long-range communication
  • Compact, efficient design for easy integration into existing setups
  • Cost-effective performance for IoT projects of any scale
  • Integrated GPS chip
The Things Network
Our products for LoRa® are ready to work with “The Things Network” - the famous open source infrastructure that provides free LoRa® network coverage and has tons of apps for your needs. With the help of “The Things Network” you can get started with the Internet-of-things within a day. And it is easily upgradable to enterprise-grade network “The Things Industries”.
The setup is so easy - anyone can learn it. No need to reinvent the wheel, join “The Things Network” to save time and energy with smart solutions!
Specification
Specifications
  • Product code R11e-LR8G
  • Suggested price $59.00
Powering
  • Max power consumption 1.3 W
Other
  • GPS RF connector type uUFL
Certification & Approvals
  • Certification CE, ROHS
  • IP 00
Documents
Brochure
.PDF
Brochure PDF first page
