Skip to main content
R11e-LR9G
The R11e-LR9G is a next-generation concentrator card for 915 MHz LoRa® networks, compatible with any MikroTik device that has a miniPCIe slot and USB lines.
Outdoors
R11e-LR9G
Product image
Product image thumbnail
The R11e-LR9G is a next-generation concentrator card for LoRa® networks, compatible with any MikroTik device that has a miniPCIe slot and USB lines. It includes:
• 915 MHz LoRa® support (AU915–928, US902–928, AS923, KR920–923)
• GPS support (MT3337V interface)
• Enhanced receive sensitivity: -141 dBm
• Max power consumption: 1.3 W
• Standard miniPCIe form factor
Now with GPS on board, the R11e-LR9G is ideal for mobile LoRa® base stations, vehicle tracking solutions, or precision deployment scenarios that benefit from time-sync or geolocation.
Specification
Specifications
  • Product code R11e-LR9G
  • Suggested price $59.00
Powering
  • Max power consumption 1.3 W
Other
  • GPS RF connector type uUFL
Certification & Approvals
  • Certification FCC, IC
  • IP 00
Documents
Brochure
.PDF
Brochure PDF first page
