Skip to main content
R11e-LR2
A new Concentrator Gateway card for LoRa® technology in mini PCIe form – so you can create or customize your own 2.4 GHz IoT projects.
Outdoors
R11e-LR2
Product image
Product image thumbnail
R11e-LR2 enables 2.4 GHz LoRa® connectivity for any MikroTik product that has a mini PCIe slot with connected USB lines. It supports 4 different RX channels and 1 TX channel. 2.4 GHz for LoRa® means significantly higher bandwidth, higher data rate, and less air time. And because of the Chirp modulation technology, it doesn’t interfere with the 2.4 GHz WLAN signal! A perfect solution for industrial setups with a high density of sensors.
Specification
Specifications
  • Product code R11e-LR2
  • Suggested price $69.00
Powering
  • Max power consumption 2 W
Certification & Approvals
  • Certification CE, FCC, IC, ROHS
Documents
Brochure
.PDF
Brochure PDF first page
