Skip to main content
LHG 5 ax
Long-range outdoor CPEs with modern Wi-Fi 6 performance, rugged design, and unbeatable pricing. Available in two models (24.5 or 27 dBi), they’re ideal for point-to-point links over great distances. This is the 24.5 dBi version.
Wi-Fi 6 for long-range links
Available in 24.5 or 27 dBi versions
WPA3 security built-in
Aerodynamic grid antenna design
Passive PoE powering (12-28V)
RouterOS V7 inside
Included all mounting hardware
Need a fast, stable connection across large distances?
Whether you’re bridging two buildings, connecting a remote site, or sharing your internet with nearby infrastructure — the new LHG Wi-Fi 6 series is built for the challenge. And here’s the best part: we’ve kept the same pricing as the previous generation. High performance, long range, and Wi-Fi 6 — all without breaking the budget.
Background image
reliable Wi-Fi 6 long-distance links
A compact, long-range CPE with a 24.5 dBi antenna.
Perfect for links up to 20 km in most scenarios.
Gigabit Ethernet with PoE Input
State-of-the-art antenna built directly into the wireless unit
Modern dual-core ARM CPU
Wi-Fi 6 can be a real game-changer! Here’s why:
The 802.11ax standard brings crucial improvements for long-distance wireless links — including better spectral efficiency, higher modulation rates (1024-QAM), and lower latency. That means stronger performance even in noisy environments and faster, more stable connections over a greater distance. Combined with WPA3 encryption and RouterOS v7, the LHG ax series is ready for the challenges of modern outdoor networking. Order yours today — and be ready too!
LHG 5 ax
Product image
Product image
Product image
Product image thumbnail
Specification
Specifications
  • Product code LHG-5axD
  • Suggested price $99.00
  • Architecture ARM 32bit
  • CPU IPQ-5010
  • CPU core count 2
  • CPU nominal frequency 800 MHz
  • CPU Threads count 2
  • RouterOS license 3
  • Operating System RouterOS v7
  • Size of RAM 256 MB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 5 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 12-28 V
Wireless specifications
  • Wireless 5 GHz Max data rate 1200 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n/ac/ax
  • Antenna gain dBi for 5 GHz 24.5
  • Wireless 5 GHz chip model QCN-6102
  • Wireless 5 GHz generation Wi-Fi 6
Ethernet
  • 10/100/1000 Ethernet ports 1
Other
  • CPU temperature monitor Yes
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP 54
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for arm devices.
System Package
Default Packages
More in download page
