Skip to main content
DPS-550AB-36G
Replacement hot-swap power supply unit for the ROSE Data Server.
DPS-550AB-36G
Product image
Product image thumbnail
Designed to match the RDS2216’s energy-efficient architecture, this hot-swap PSU helps maintain the platform’s low power consumption and reduced heat output — fully aligned with the eco-friendly vision behind the Rose Data Server.
Output voltage: 12V / Output power: 550W.
Download Brochure
Specification
Specifications
  • Product code DPS-550AB-36G
  • Suggested price $139.00
Documents
