Skip to main content
GrooveA 52 ac
2.4GHz/5GHz AP/Backbone/CPE with 802.11ac and Gigabit Ethernet, N-male connector + Omni antenna
IP 55
Outdoors
PoE
GrooveA 52 ac
Product image
Product image
Product image thumbnail
Our smallest outdoor series model - a fully featured wireless RouterBOARD powered by RouterOS.
Weatherproof, durable and ready to use. Now with 802.11ac support, a Gigabit Ethernet port and a selectable wireless band (2.4GHz or 5GHz, up to 80 MHz wide channel). The new Gigabit port will help you utilise the full benefit of 802.11ac high speed wireless.
The Groove A (AP model) comes with Level 4 license and includes a Dual Band 2.4/5GHz Omni directional antenna (6dBi 2.4GHz, 8dBi 5GHz), so you can use the unit right out of the box, or use your own antenna.
- RBGrooveGA-52HPacn-US (USA) is factory locked for 2412-2462MHz, 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
- RBGrooveGA-52HPacn (International) supports 2412-2484MHz and 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
Specification
Specifications
  • Product code RBGrooveGA-52HPacn
  • Suggested price $99.00
  • Architecture MIPSBE
  • CPU QCA9556
  • CPU core count 1
  • CPU nominal frequency 720 MHz
  • Dimensions 177 x 44 x 44 mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 5 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 10-30 V
Wireless specifications
  • Wireless 2.4 GHz/5 GHz Max data rate 433 Mbit/s
  • Wireless 2.4 GHz/5 GHz Number of chains 1
  • Wireless 2.4 GHz/5 GHz standards 802.11b/g/n, 802.11a/n/ac
  • Antenna gain dBi for 2.4 GHz/5 GHz 6
  • Wireless 2.4 GHz/5 GHz chip model QCA9889
  • Wireless 2.4 GHz/5 GHz generation Wi-Fi 5
Ethernet
  • 10/100/1000 Ethernet ports 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP55
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
System Package
Default Packages
More in download page
Related Products
