Skip to main content
Discontinued
mANT 15s
Dual-polarization 5Ghz 15dBi 120 degree beamwidth antenna with two RP-SMA connectors
mANT 15s
Product image
Product image
Product image
Product image
Product image
Product image
Product image thumbnail
The new sector mANT antennas are the perfect companion for the BaseBox, NetBox, NetMetal or any other outdoor wireless device.
The mANT is a dual-polarization 15dBi 120 degree beamwidth antenna with two RP-SMA connectors. It is compatible with the SXT type mount, so you can use it with our durable and adjustable QuickMount systems. It comes with quickMOUNT PRO.
Specification
Specifications
  • Product code MTAS-5G-15D120
  • Suggested price $59.00
  • Beamwidth 120 deg (azimuth) 10 deg (elevation)
  • Connector two RP-SMA
  • Cross Polarization >30 dB
  • Diameter x Depth 140 x 348 x 82 mm
  • Frequency Range 5.17 - 5.825 GHz
  • Front-to-Back Ratio >30 dB
  • Polarization Vertical and horizontal
  • Port to Port Isolation >40 dB min
  • VSWR 1.43 typ, 1.8 max
  • Weight 734 g
Certification & Approvals
  • Certification CE, ROHS
Documents
Brochure
.PDF
Brochure PDF first page
