Skip to main content
Chateau PRO ax
A Wi-Fi 6 home access point for the advanced users – it comes with an exceptionally powerful wireless system and a matching CPU.
ARM64
Quad-core CPU
PoE
ROS v7
WiFi 6
Dual-band
Chateau PRO ax
Product image
Product image
Product image
Product image thumbnail
Designed with professional users in mind, the Chateau PRO ax Wi-Fi 6 home access point is engineered to squeeze out maximum performance, handling more traffic than ever before. With its unstoppable quad-core ARM CPU running at 2.2 GHz and our latest cutting-edge wireless chip, Chateau PRO ax leverages 4 spatial streams to achieve double the data rate of the usual dual-chain devices, ensuring that your network is always fast, reliable, and ready to support even the most demanding tasks. Remember – you will need a device that supports 4 spatial streams on the other side of the connection to fully utilize the Chateau PRO ax.
With 5x Gigabit Ethernet ports and a USB 3.0 port, you can transform this Chateau into a home media server by plugging in an additional SSD storage. Or you could use the USB to add an LTE modem for backup!
Advanced container setups, bonding, or high-speed 4x4 MIMO wireless setups – that’s where the Chateau PRO ax can really shine! Also, its increased number of radio transceivers provides significantly improved wireless coverage and beamforming performance.
Video thumbnail
Specification
Specifications
  • Product code H53UiG-5HaxQ2HaxQ
  • Suggested price $199.00
  • Architecture ARM 64bit
  • CPU IPQ-8072A
  • CPU core count 4
  • CPU nominal frequency 2208 MHz
  • CPU Threads count 4
  • Switch chip model IPQ-8072
  • RouterOS license 6
  • Operating System RouterOS v7
  • Size of RAM 1 GB
  • Storage size 128 MB
  • Storage type NAND
Wireless capabilities
  • Wireless 2.4 GHz Max data rate 1148 Mbit/s
  • Wireless 2.4 GHz Number of chains 4
  • Wireless 2.4 GHz standards 802.11b/g/n/ax
  • Antenna gain dBi for 2.4 GHz 5
  • Wireless 2.4 GHz chip model QCN-5024
  • Wireless 2.4 GHz generation Wi-Fi 6
  • Wireless 5 GHz Max data rate 2400 Mbit/s
  • Wireless 5 GHz Number of chains 4
  • Wireless 5 GHz standards 802.11a/n/ac/ax
  • Antenna gain dBi for 5 GHz 6
  • Wireless 5 GHz chip model QCN-5054
  • Wireless 5 GHz generation Wi-Fi 6
  • WiFi speed AX3600
Ethernet
  • 10/100/1000 Ethernet ports 5
  • Number of 1G Ethernet ports with PoE-out 1
Peripherals
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB 3.0 type A
  • Max USB current (A) 1.5
Powering
  • Number of DC inputs 1 (DC jack)
  • DC jack input Voltage 18-57 V
  • Max power consumption 55 W (Networked standby (HiNA) ≤ 8 W)
  • Max power consumption without attachments 18 W
  • Cooling type Passive
PoE-out
  • PoE-out ports Ether5
  • PoE out Passive PoE up to 57V
  • Low voltage PoE-Out current limit 600 mA
  • High voltage PoE-Out current limit 500 mA
  • Max total out (A) 0.600 A
  • Total output current 0.600
  • Total output power 22.8
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP 20
Other
  • CPU temperature monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Mode button Yes
Included parts
Note
Ethernet test results
IPsec test results
Download
Latest RouterOS stable release v7.25 download files for arm64 devices.
System Package
Default Packages
More in download page
