Skip to main content
HGO-LTE-W
A handy IoT combo antenna for both LTE and LoRa® frequencies. Perfect for the MikroTik KNOT LR series!
Outdoors
HGO-LTE-W
Product image
Product image thumbnail
No need to buy several antennas for your Internet-of-things setups – just grab the new HGO-LTE-W antenna that can handle an impressive frequency spectrum: 699MHz – 3,8GHz. That’s right – you can use the same antenna for LTE/5G, CAT-M/NB and LoRa® connectivity.
This antenna will transmit whichever signal your modem provides. For example, if you are using our KNOT LR8/LR9 kit, you can use this powerful 1.5 – 4 dBi antenna to communicate with all your 868 MHz devices and then send the data to the cloud via LTE.
Connector type: RP-SMA male
Specification
Specifications
  • Product code HGO-LTE-W
  • Suggested price $9.00
  • Can be used indoors Yes
  • Can be used outdoors Yes
Documents
Brochure
.PDF
Brochure PDF first page
