Skip to main content
Chateau LTE12 (2025)
Your best friend when it comes to mobile networks. Amazing in the hands of seasoned system administrators. Or in a household with zero IT skills. Or anything in between. Chateau can do it all. New modem by Quectel: added 4x4 MIMO for more bands: 1 / 3 / 7 / 38 / 40 / 41. 5x Gigabit Ethernet ports, 600 Mbps Cat12 LTE.
ARM
Quad-core CPU
LTE Cat12
MIMO 4x4
ROS v7
Dual-band
Product image
Product image
Product image
Product image thumbnail
Remove the bottleneck in your mobile internet setup
Are you tired of ISP or operator-issued routers that limit your speed and coverage? Chateau LTE12 is the solution, delivering faster, more reliable mobile internet, whether you are in the city or the countryside. With carrier aggregation and expanded 4x4 MIMO support, you’ll experience:
  • Faster speeds in crowded areas
  • More stable connections in remote locations
  • Wider coverage across multiple LTE bands
New and improved LTE connectivity
  • Upgraded LTE12 modem for stronger, reliable connections.
    Expanded 4x4 MIMO support on more bands: 1 / 3 / 7 / 38 / 40 / 41
  • Dual-band Wi-Fi for seamless performance across all devices
  • Now with B32 support for improved LTE performance in supported regions!
Built for homes and businesses
  • 5x Gigabit Ethernet ports to connect media servers, PC towers, TVs, or smart home systems.
  • Dual-band Wi-Fi (2.4 GHz & 5 GHz) ensures stable connections for all your devices.
  • External LTE antenna support (SMA female ports) to boost signal strength in tricky signal areas.
  • RouterOS for advanced security, VPNs, and full network control.
Stay ahead of connectivity challenges with the improved Chateau LTE12. Powerful, secure, and designed to keep you connected—anytime, anywhere!
Specification
Specifications
  • Product code D53G-5HacD2HnD-TC&EG120K-EA
  • Suggested price $179.00
  • Architecture ARM 32bit
  • CPU IPQ-4019
  • CPU core count 4
  • CPU nominal frequency 448-896 (auto) MHz
  • CPU Threads count 4
  • Switch chip model IPQ-4019
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 256 MB
  • Storage size 32 MB
  • Storage type FLASH
  • Tested ambient temperature -20°C to 70°C
Powering
  • Number of DC inputs 1 (DC jack)
  • DC jack input Voltage 12-28 V
  • Max power consumption 24 W
  • Max power consumption without attachments 18 W
  • Cooling type Passive
Mobile
  • 3G Category R8 (42.2Mbps Downlink, 5.76Mbps Uplink)
  • 3G bands 1 (2100MHz)
    3 (1800MHz)
    5 (850MHz)
    8 (900MHz)
  • LTE Category 12 (600Mbps Downlink, 150Mbps Uplink)
  • MIMO DL 4x4
  • MIMO UL 1x1
  • LTE FDD bands 1 (2100MHz)
    3 (1800MHz)
    5 (850MHz)
    7 (2600MHz)
    8 (900 MHz)
    20 (800MHz)
    28 (700MHz)
    32 (1500 MHz)
  • LTE TDD bands 38 (2600MHz)
    40 (2300MHz)
    41 (2500MHz)
  • TAC 86642205
Wireless specifications
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 2
  • Wireless 2.4 GHz chip model IPQ-4019
  • Wireless 2.4 GHz generation Wi-Fi 4
  • Wireless 5 GHz Max data rate 867 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n/ac
  • Antenna gain dBi for 5 GHz 4
  • Wireless 5 GHz chip model IPQ-4019
  • Wireless 5 GHz generation Wi-Fi 5
Ethernet
  • 10/100/1000 Ethernet ports 5
Peripherals
  • Number of SIM slots 1 Modem (Micro SIM)
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • Mode button Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP 20
Included parts
Note
Wireless Specification
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for arm devices.
System Package
Default Packages
More in download page
Related Products
