Skip to main content
CRS520-4XS-16XQ-RM
An ultra-fast enterprise switch with extra processing power due to the CCR series CPU & the best price per 100 Gigabit port on the market!
ARM64
Quad-core CPU
10G
100G
ROS v7
CRS520-4XS-16XQ-RM
Product image
Product image
Product image
Product image thumbnail
Welcome to the forefront of networking: the future-proof CRS520-4XS-16XQ-RM with extra processing power, 4 GB of DDR4 RAM, and the best price per 100 Gigabit port we’ve seen so far.
With 16x 100 Gigabit QSFP28 ports, 4x 25 Gigabit SFP28 ports, and an extra pair of 10 Gigabit Ethernet ports, this switch can bring a lot of value to complicated enterprise networks, data centers, multimedia studios, and other setups where you would typically use several devices. Now – a single CRS520 can do the trick!
Avid CCR users might recognize the powerful quad-core ARM CPU running at 2 GHz, and ask – why would a switch need all that power? Two reasons:
1) CRS520 is more than a switch. You can run OSPF/BGP, out-of-band/management VPNs, ACLs, Jumbo frames and even L3HW Offloaded routing;
2) Future-proofing: as our friends at Marvell keep expanding the capabilities of their spectacular switch-chips, our in-house software team is busy exploring ways to add even more Hardware Offloaded features. You can expect software updates that will take the CRS520 to the next level! And all that without any paywalls or subscriptions.
Two hot-swap power supplies and four hot-swap fans for cooling are included. This switch can also be powered by the PW48V-12V150W Hot Swap -48V DC telecom power supply, available separately.
Video thumbnail
Specification
Specifications
  • Product code CRS520-4XS-16XQ-RM
  • Suggested price $2,195.00
  • Architecture ARM 64bit
  • CPU AL52400
  • CPU core count 4
  • CPU nominal frequency 2 GHz
  • CPU Threads count 4
  • Switch chip model 98CX8410
  • RouterOS license 5
  • Operating System RouterOS v7
  • Size of RAM 4 GB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -20°C to 50°C
Powering
  • Number of AC inputs 2
  • AC input range 100-240
  • Number of PSU slots 2
  • Frequency (Hz) 50-60
  • Max power consumption 150 W (220 W with both PSUs)
  • Max power consumption without attachments 123 W
  • Cooling type 4 fans
Ethernet
  • Number of 1G/2.5G/5G/10G Ethernet ports 2 (supported: 10M/100M/1G/10G)
Fiber
  • Number of 25G SFP28 ports 4
  • Number of 100G QSFP28 ports 16
Peripherals
  • Serial console port RJ45
Other
  • CPU temperature monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP 20
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for arm64 devices.
System Package
More in download page
