Skip to main content
wAP LR9G kit
The wAP LR9G kit is a rugged, out-of-the-box LoRa® 915 MHz gateway built into MikroTik’s proven wAP form factor.
Automotive
GPS
IoT
IP 54
Mini PCI-e
Outdoors
PoE
ROS v7
wAP LR9G kit
Product image
Product image
Product image
Product image thumbnail
The wAP LR9G kit is a rugged, out-of-the-box LoRa® gateway built into MikroTik’s proven wAP form factor. It features:
• LoRa® 915 MHz support
• Built-in GPS (via MT3337V)
• Improved Rx sensitivity: up to -141 dBm
• 2.4 GHz Wi-Fi (802.11b/g/n dual-chain)
• Passive PoE support and wide voltage input range
• 3 power input options: PoE, automotive, or DC jack
• SMA female connectors for external antenna options
Pair it with any public or private LoRa® network (including The Things Network or The Things Industries) using the preinstalled UDP packet forwarder. Whether you’re deploying smart irrigation in a field or setting up a LoRa® node on a building rooftop – this device is made to withstand the elements and simplify setup.
*) the device has no built in LTE modem, the SIM slot can only be used, if LoRa interface card is removed and replaced by an LTE modem
Specification
Specifications
  • Product code RBwAPR-2nD&R11e-LR9G
  • Suggested price $149.00
  • Architecture MIPSBE
  • CPU QCA9531
  • CPU core count 1
  • CPU nominal frequency 650 MHz
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
  • Tested ambient temperature -40°C to 60°C
Powering
  • Number of DC inputs 3 (DC jack, PoE-IN, Automotive)
  • DC jack input Voltage 9-28 V
  • Automotive input Voltage 12-30 V
  • Max power consumption 7 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 9-28 V
Wireless specifications
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 2
  • Wireless 2.4 GHz chip model QCA9531
  • Wireless 2.4 GHz generation Wi-Fi 4
Ethernet
  • 10/100 Ethernet ports 1
Peripherals
  • Number of SIM slots 1 Modem (Mini SIM)
  • MiniPCI-e slots 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • GPS RF connector type uUFL
Certification & Approvals
  • Certification FCC, IC, EAC
  • IP 54
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Related Products
