Skip to main content
hEX refresh
The classic hEX refresh: same price, twice the performance! The staple of affordable routing for every home is back – stronger than ever due to the modern ARM CPU and extra RAM.
ARM
PoE
ROS v7
hEX refresh
Product image
Product image
Product image thumbnail
The affordable, reliable router you know and trust is now stronger than ever. With the latest refresh, the hEX delivers twice the performance for the same great price. Whether you’re looking for a rock-solid solution for your home or small office, hEX ensures seamless and stable connectivity with a powerful upgrade: we’ve increased the RAM from 256 MB to 512 MB, and replaced the CPU with a modern ARM dual-core workhorse!
Depending on your configuration, the performance increase can reach 100-134%! With 5x Gigabit Ethernet ports, hEX is the most cost-effective way to interconnect your main home or office devices. And you can use the full-sized USB port to add extra storage to stream high-quality media across devices!
Video thumbnail
Specification
Specifications
  • Product code E50UG
  • Suggested price $59.95
  • Architecture ARM 32bit
  • CPU EN7562CT
  • CPU core count 2
  • CPU nominal frequency 950 MHz
  • CPU Threads count 2
  • Switch chip model EN7523
  • Dimensions 113x89x28mm
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 512 MB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 12-28 V
  • Max power consumption 10 W
  • Max power consumption without attachments 4 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 12-28 V
Ethernet
  • 10/100/1000 Ethernet ports 5
Peripherals
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • CPU temperature monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Mode button Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP 20
Included parts
Note
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for arm devices.
System Package
More in download page
