Skip to main content
CSS318-16G-2S+IN
With 16 Gigabit Ethernet ports and 2 SFP+ 10G uplink ports, you get all the connectivity you need without unnecessary bulk. Stack two units side by side in a single 1U rack space for even greater flexibility and scalability.
SFP/SFP+
CSS318-16G-2S+IN
Product image
Product image
Product image
Product image thumbnail
The CSS318-16G-2S+IN is a perfect fit for setups where 24 ports are too many and 8 ports just aren’t enough. Its compact 10-inch form factor and cost-effective design make it the ideal solution for small and medium-sized offices, home networks, or rackmount environments where space and efficiency are key.
With 16 Gigabit Ethernet ports and 2 SFP+ 10G uplink ports, you get all the connectivity you need without unnecessary bulk. With its versatile mounting options, the CSS318-16G-2S+ can be installed in 10-inch racks, standard 19-inch racks, or even side-by-side—fitting two switches in a single 1U 19-inch space.
Effortless Configuration with SwOS
Configuration is effortless with MikroTik’s lightweight SwOS. Accessible directly from your web browser, SwOS gives you the core functionality of a managed switch and more:
  • Port-to-port forwarding
  • Broadcast storm control
  • MAC filtering
  • VLAN configuration
  • Traffic mirroring
  • Bandwidth limitation
  • Adjustment of MAC and IP header fields
Energy Efficient and Reliable
The CSS318 consumes just 10W without attachments and up to 13W under full load, keeping your network reliable while saving power.
Compact, Scalable, and Affordable
Compact, scalable, and simple to configure — the CSS318-16G-2S+IN is ready to enhance your network at an unbeatable price.
Video thumbnail
Specification
Specifications
  • Product code CSS318-16G-2S+IN
  • Suggested price $139.00
  • Switch chip model 98DX2518
  • Operating System SwOS
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of AC inputs 1
  • AC input range 100-240
  • Frequency (Hz) 50-60
  • Max power consumption 13 W
  • Max power consumption without attachments 10 W
  • Cooling type Passive
Ethernet
  • 10/100/1000 Ethernet ports 16
Fiber
  • SFP+ ports 2
Other
  • CPU temperature monitor Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP 20
Included parts
Note
Switching results
Documents
Brochure
.PDF
Brochure PDF first page
Related Products
