Skip to main content
CRS310-8G+2S+IN
Take advantage of the blazing fast 2.5/10 Gigabit combo and upgrade your workspace! This switch can utilize the full potential of RouterOS v7: run VLANs, Jumbo frames, link aggregation, ACL rules, and so much more!
ARM
Dual boot
2.5G
ROS v7
SFP/SFP+
CRS310-8G+2S+IN
Product image
Product image
Product image
Product image thumbnail
The world of networking is on the move. Even small offices are shifting from Gigabit connections to the lightning-fast realm of 2.5 Gigabit connectivity. With CRS310-8G+2S+IN, we aim to give you the tools to outpace your competition with a strong combination of eight 2.5 Gigabit Ethernet ports and two 10 Gigabit SFP+ ports in a compact, powerful package! Furthermore, these SFP+ cages support multiple data rates: 1G, 2.5G, and 10G. So you can use this switch as a 10x 2.5G switch, if needed. Classic MikroTik flexibility!
The amazing Marvell 98DX226S switch-chip and integrated dual-core ARM CPU can handle the full potential of RouterOS v7. Run VLANs, Jumbo frames, link aggregation, ACL rules, and so much more! You can even do some hardware offloaded Layer-3 routing.
There are multiple mounting options. You can easily install the CRS310-8G+2S+IN in a standard 19” rack using the provided rackmount ears. Another option is to get the RMK-2/10 accessory set, which allows you to mount two CRS310 units within the same 1U 19” rack space or mount it in a 10” rack. The choice is yours!
Video thumbnail
Specification
Specifications
  • Product code CRS310-8G+2S+IN
  • Suggested price $219.00
  • Architecture ARM 32bit
  • CPU 98DX226S
  • CPU core count 2
  • CPU nominal frequency 800 MHz
  • Switch chip model 98DX226S
  • Dimensions 200 x 206,1 x 44
  • RouterOS license 5
  • Operating System RouterOS v7 / SwitchOS
  • Size of RAM 256 MB
  • Storage size 32 MB
  • Storage type FLASH
  • Tested ambient temperature -40°C to 60°C
Powering
  • Number of DC inputs 1 (DC jack)
  • DC jack input Voltage 18-57 V
  • Max power consumption 34 W
  • Max power consumption without attachments 21 W
  • Cooling type 1 fan
Ethernet
  • Number of 2.5G Ethernet ports 8
Fiber
  • SFP+ ports 2
Peripherals
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • CPU temperature monitor Yes
  • PCB temperature monitor Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP 20
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for arm devices.
Latest SwitchOS release v2.19 download files for css310g devices.
More in download page
