Skip to main content
New Discontinued
LtAP LR8G LTE6 kit
A rugged all-in-one device (LoRa®, 2.4 GHz Wireless, built-in GPS, fast Cat6 LTE mobile internet) with multiple powering options.
Automotive
GPS
IoT
LTE Cat6
Mini PCI-e
Outdoors
PoE
ROS v7
LtAP LR8G LTE6 kit
Product image
Product image thumbnail
A rugged all-in-one device for IoT connectivity, ideal for industrial or public use. Perfect for transportation projects or logistics, the LtAP LR8G LTE6 Kit combines:
  • LoRa® connectivity, LTE, and GPS for maximum versatility
  • Dual-chain 2.4 GHz WiFi for added flexibility
  • A tough, robust enclosure built for industrial and mobile setups
  • Mini SIM slot and a built-in modern LTE6 modem for fast and responsive mobile connectivity
  • Enhanced 868MHz Rx sensitivity for effective long-range communication
  • Many powering options, including automotive
  • SMA female connectors for external antennas
The Things Network
Our products for LoRa® are ready to work with “The Things Network” - the famous open source infrastructure that provides free LoRa® network coverage and has tons of apps for your needs. With the help of “The Things Network” you can get started with the Internet-of-things within a day. And it is easily upgradable to enterprise-grade network “The Things Industries”.
The setup is so easy - anyone can learn it. No need to reinvent the wheel – join “The Things Network” to save time and energy with smart solutions!
Specification
Specifications
  • Product code LtAP-2HnD&FG621-EA&LR8G
  • Suggested price $249.00
  • Architecture MMIPS
  • CPU MT7621AT
  • CPU core count 2
  • CPU nominal frequency 880 MHz
  • CPU Threads count 4
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 128 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 3 (DC jack, PoE-IN, Automotive)
  • DC jack input Voltage 12-30 V
  • Automotive input Voltage 12-27 V
  • Max power consumption 24 W
  • Max power consumption without attachments 12 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 12-30 V
Mobile
  • 3G Category R8 (42.2Mbps Downlink, 11.2Mbps Uplink)
  • 3G bands 1 (2100MHz)
    3 (1800MHz)
    5 (850MHz)
    8 (900MHz)
  • LTE Category 6 (300Mbit/s Downlink, 50Mbit/s Uplink)
  • MIMO DL 2x2
  • MIMO UL 1x1
  • LTE FDD bands 1 (2100MHz)
    3 (1800MHz)
    5 (850MHz)
    7 (2600MHz)
    8 (900 MHz)
    20 (800MHz)
    28 (700MHz)
  • LTE TDD bands 38 (2600MHz)
    40 (2300MHz)
    41 (2500MHz)
  • TAC 86335904
Wireless specifications
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 2.5
  • Wireless 2.4 GHz chip model AR9342
  • Wireless 2.4 GHz generation Wi-Fi 4
Ethernet
  • 10/100/1000 Ethernet ports 1
Peripherals
  • Number of SIM slots 3 Modem (Mini SIM)
  • MiniPCI-e slots 2
  • Serial console port RS232
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • GNSS standards GPS
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP X0
Included parts
Note
Wireless Specification
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for mmips devices.
System Package
Default Packages
More in download page
