Skip to main content
GPEN21
Smart power injector that serves as an advanced software controlled repeater
PoE
SFP/SFP+
GPEN21
Product image
Product image
Product image
Product image
Product image thumbnail
The GPEN21 is a smart power injector that serves as an advanced software controlled repeater. Not only can it power your uplink devices via PoE, it can also provide a range of useful software features:
• Interface management and monitoring
• GPEN link fault detection
• VLAN support
• SNMP reporting
• Basic traffic shaping
GPEN21 has an Ethernet and SFP port for fiber connectivity. Customers can choose to use GPEN21 to power optical module for uplink to provider, or to provide PoE to power Ethernet uplink to provider (that uses our GPeR and/or netPower products) The GPEN unit can be securely attached to a wall or the communications cabinet. The Ethernet cable can be routed either directly through its bottom cable opening or into the wall, as preferred.
Specification
Specifications
  • Product code GPEN21
  • Suggested price $40.00
  • Switch chip model 88E6341
  • Operating System SwitchOS Lite
  • Input voltage 12 - 57 V, Passive or 802.3af/at
  • Tested ambient temperature -20°C to 70°C
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 12-57 V
  • Max power consumption 30 W
  • Max power consumption without attachments 3 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 12-57 V
PoE-out
  • PoE-out ports Ether2
  • PoE out Passive PoE up to 57V
  • Low voltage PoE-Out current limit 850 mA
  • High voltage PoE-Out current limit 625 mA
  • Max total out (A) 850 mA
Ethernet
  • 10/100/1000 Ethernet ports 2
  • Number of 1G Ethernet ports with PoE-out 1
Fiber
  • SFP ports 1
Other
  • Output Voltage Yes, Passive PoE up to 57 V
  • Mode button Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP20
Included parts
Note
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest SwitchOS Lite release v2.21 download files for gpen21 devices.
System Package
More in download page
