Skip to main content
Discontinued
LHG XL 5 ac
Dual chain Long Range 27dBi 5GHz CPE/Point-to-Point Integrated Antenna with AC support and Gigabit Ethernet
ARM
Quad-core CPU
IP 54
Outdoors
PoE
LHG XL 5 ac
Product image
Product image
Product image
Product image thumbnail
The LHG XL 5 ac is Long Range 5GHz 802.11ac wireless device with an integrated dual polarization 27 dBi grid antenna at a revolutionary price. It is perfect for point to point links or for use as a CPE at longer distances and supports Nv2 TDMA protocol.
The device includes one 10/100/1000 Mbit Ethernet port to fully utilize speeds that 802.11ac protocol provides.
- LHG XL 5 ac-US (USA) is factory locked for 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
- LHG XL 5 ac (International) supports 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
Shipped as a kit of 4 units (RBLHGG-5acD-XL4pack) - 4 antennas in a single box.
Specification
Specifications
  • Product code RBLHGG-5acD-XL
  • Suggested price $117.00
  • Architecture ARM 32bit
  • CPU IPQ-4018
  • CPU core count 4
  • CPU nominal frequency 488-896 (auto) MHz
  • CPU Threads count 4
  • Dimensions Ø 550 x 245 mm;
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 256 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 8 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 10-30 V
Wireless specifications
  • Wireless 5 GHz Max data rate 867 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n/ac
  • Antenna gain dBi for 5 GHz 27
  • Wireless 5 GHz chip model IPQ-4018
  • Wireless 5 GHz generation Wi-Fi 5
Ethernet
  • 10/100/1000 Ethernet ports 1
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP54
Included parts
Note
Wireless Specification
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for arm devices.
System Package
Default Packages
More in download page
Related Products
