Skip to main content
KNOT LR8G kit
An industrial-grade IoT gateway for smart asset tracking, remote monitoring, and efficient automation – now with enhanced LoRa® reception, concurrent GPS + LTE CAT-M, and a lower price. This is the 868 MHz version.
LoRa® 868MHz
CAT-M/NB technology
2.4 GHz wireless
RS485/Modbus
2x 100 Mbps Ethernet ports
PoE Input & PoE Output
GNSS
GPIO
Bluetooth
Smart IoT Connectivity That Just Works
The KNOT LR8G is a compact, out-of-the-box gateway for LoRa®-based networks, designed to bring affordable, reliable connectivity to even the most remote or infrastructure-light environments. It supports LTE CAT-M1 and NB2, Bluetooth 5.2, 2.4 GHz Wi-Fi, GPS, and Ethernet with PoE, making it a flexible centrepiece for any IoT deployment.
CAT-M1 and NB2 mobile internet connectivity allows you to save tons of money and remotely monitor and manage equipment without needing high-cost data plans or full LTE coverage.
Whether you’re tracking high-value assets across a hospital, managing a vending machine in a shopping mall, or monitoring sensors in an agricultural field – the KNOT LR8G ties everything together and keeps everything connected.
Background image
Key Features & Upgrades
Concurrent GPS and LTE CAT-M
Track assets in motion with precise GPS while maintaining a live LTE CAT-M1 connection. Ideal for mobile units like service vehicles, containers, or roaming field equipment
Improved 868 MHz LoRa® Reception
Enhanced sensitivity for stronger signal and longer range, even in interference-heavy environments.
Versatile Powering
Choose from PoE Input, DC jack, or MicroUSB – including PoE Output on Ether2 for powering other devices
Lower Price, Same Reliability
Cost-effective for large-scale deployments without sacrificing performance.
SMA Female Connectors for All Main Interfaces
Easy antenna setup for LTE, GPS, and LoRa®
Powered by RouterOS v7
Full control, custom scripting, and advanced routing features.
Background image
Background image
Practical Use Cases
Background image
Hospital Asset Tracking
Attach Bluetooth beacons to critical medical equipment. Install a KNOT LR8G in each storage area. As gear moves, KNOT detects nearby tags, tracks location via GPS, and sends updates over LTE CAT-M – keeping inventory up-to-date and reducing manual audits
Background image
Cold Chain Monitoring
Use wired Modbus sensors to monitor temperature and humidity inside refrigerated containers. KNOT converts Modbus to TCP and forwards data securely via MQTT or HTTPS, using low-bandwidth LTE or NB-IoT
Background image
Agriculture & Remote Sites
Deploy KNOT to gather soil or weather sensor data in rural fields. Its wide band support, LoRa® reception, GPS compatibility make it ideal for long-range, low-power data collection.
Background image
Industrial Automation
Bridge legacy wired sensors and actuators to the cloud. With DIN rail support and GPIO monitoring, KNOT easily integrates into industrial cabinets or manufacturing environments
Lightweight, Powerful, Cost-Effective
At just 6W consumption and small footprint (122 × 87 × 26 mm), the KNOT LR8G is perfect for deployments where space, power, and budget are limited – but performance can’t be.
Background image
Track, monitor, automate – smarter and cheaper than ever before.
KNOT LR8G kit
Product image
Product image
Product image
Product image thumbnail
Specification
Specifications
  • Product code RB924iR-2nD-BT5&BG770A&R11e-LR8G
  • Suggested price $179.00
  • Architecture MIPSBE
  • CPU QCA9531
  • CPU core count 1
  • CPU nominal frequency 650 MHz
  • Switch chip model QCA9531
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 64 MB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • MicroUSB input Voltage 5 V
  • Number of DC inputs 3 (DC jack, PoE-IN, MicroUSB)
  • DC jack input Voltage 12-57 V
  • Max power consumption 23 W
  • Max power consumption without attachments 6 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 18-57 V
PoE-out
  • PoE-out ports Ether2
  • PoE out Passive PoE
  • Low voltage PoE-Out current limit 650 mA
  • High voltage PoE-Out current limit 450 mA
  • Total output power 12
Wireless specifications
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 1.5
  • Wireless 2.4 GHz chip model QCA9531
  • Wireless 2.4 GHz generation Wi-Fi 4
Ethernet
  • 10/100 Ethernet ports 2
Peripherals
  • Number of SIM slots 1 Smart card (Nano SIM)
  • MiniPCI-e slots 1
  • Serial console port RS485
  • Number of USB ports 1
  • USB slot type microUSB type AB
  • Max USB current (A) 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Bluetooth version 5.2
  • Bluetooth RF connector type uUFL
  • GPS RF connector type SMA
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP 20
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
System Package
Default Packages
More in download page
